TPMS and key fobs
Old 12-20-2013, 09:11 PM
Red Devil Z51
Support Corvetteforum!
Red Devil Z51's Avatar
Default TPMS and key fobs
Any 1 know if the key fob receiver also read the tire pressure or it a different piece?
This is on a 98 vert.
Old 12-20-2013, 09:22 PM
jamieo
jamieo's Avatar
They both work through the same receiver.
Old 12-20-2013, 09:24 PM
Red Devil Z51
Default crapola
well that sucks since im only able to sync but 1 key fob
so im thinking the receiver is bad
any idea what to do
Old 12-20-2013, 09:28 PM
jamieo
jamieo's Avatar
Are your tire sensors showing a reading?
Old 12-20-2013, 09:47 PM
Red Devil Z51
Default sensor
3 of the 4 tire sense ors would reset and i get a reading using the menu in the dash'
Old 12-20-2013, 09:52 PM
jamieo
jamieo's Avatar
The problem in is your 2nd key fob,not the receiver.
Old 12-20-2013, 11:10 PM
BigGun
BigGun's Avatar
Old 12-21-2013, 12:03 AM
65GGvert
65GGvert's Avatar
Received 3,220 Likes on 2,302 Posts
The receiver is not your problem. Sounds like you have one bad fob and one bad tpms. You can try resoldering the connections in the fob. Search (using google) 'corvette forum legendary fix"
Old 12-21-2013, 12:06 AM
65GGvert
65GGvert's Avatar
I searched it for you:
http://forums.corvetteforum.com/c5-t...em-solved.html
Old 12-21-2013, 12:25 AM
Red Devil Z51
Default yeah
I resolered teh chips in both but was still losing sync every day
So i resoldered the antenna on the receiver which was Very loose.
It then held the code for a week then i had to disconnect teh receiver to put it back in place. Now i cant get tehe2nd fob to resync.
So i think u all may be right. I have a club member close by with a 97 coupe gonna try and get with him and try his fobs and see how that works
Old 12-21-2013, 11:00 PM
Burkdog62
Burkdog62's Avatar
What is the relation of the TPMS to the key fobs? None of my TPMS sensors are giving readings and my key fob will not sync. Where do I start?
Old 12-21-2013, 11:01 PM
Burkdog62
Burkdog62's Avatar
Sorry don't mean to hijack the thread but I don't want to start a new thread for something that is already out there!
Old 12-21-2013, 11:16 PM
Red Devil Z51
Default relation
From what i have been told both key fobs and TPMS units work thru the same receiver . In a convertable it is mounted behind the drivers side rear radio speaker. U might want to pull it out and open it and make sure the antenna part is well attached. Mine was so loose it almost just fell off. So start by looking there and also put new batteries in the key fobs
Old 12-22-2013, 02:15 PM
jcgunn
jcgunn's Avatar
How old are the TPMS sensors? If they are OEM for a 98, they are way past their lifespan.
Old 12-22-2013, 04:57 PM
Burkdog62
Burkdog62's Avatar
These are oem sensors on a 99 coupe.
Old 12-22-2013, 06:09 PM
jcgunn
jcgunn's Avatar
So the batteries are dead. Get some replacements from Gene at GM Parts house. The bummer is you have to take the tires off the rims. Might just wait until next time you get new tires.
Old 12-23-2013, 11:56 AM
FRC Carmichael
FRC Carmichael's Avatar
Default FOB Receiver
Originally Posted by 8VETTE7
There is one receiver in the car and there are two types of transmitter devices , TPMS and key FOB's.
The transmitters encode a signal and data and transmit it. The Receiver decodes the signal (figures out which device sent the transmission) and passes the data to the BCM, PCM and IPC.
Other than both the TPMS and FOB's using the same receiver, there is no interaction between FOB's and TPMS.
You likely have two problems, bad batterys in the TPMS if they are original to the car and bad FOB's with broken solder joints on the circuit boards of the FOB's. The link that 65GGvert posted above addresses the solder joints in the FOB's. Here is a thread on replacing the batteries in the TPMS:
http://forums.corvetteforum.com/c5-t...batteries.html
I'm having similar issues but also getting a code for "No Communication" with the receiver. How do I trouble shoot/test the receiver?I did check the wiring harness connection and it seems fine.
To TPMS and key fobs
Quick Reply: TPMS and key fobs
