TPMS> ITM Uni-Sensors 97, 98, 99 Owners Chime In
Cruise-In VI Veteran
Getting ready to put on some new tires >meats< on the ride and going to swap out the TPMSs while the meats are off the wheels. As I have a 1999, finding fresh (batteries) OEM TPMSs is very difficult. Additionally, I do not want to swap out the receiver, TPMSs and fobs as I do enjoy the features the 99 Fobs.
Im looking at a set of ITM Uni-Sensors and as I understand, you can NOT use the standard DIC tire training method (with large magnet) to train these ITM Uni-Sensors to each wheel.
Are there any 1997, 1998 or 1999 owners on the CF that installed these ITM Uni-Sensors in their wheels?
Did the tire shop clone your replacement sensors from your original sensors?
Did the tire shop use a magnet to activate your original sensors to capture the RF ID number to use and program into the ITM Uni-Sensors?
If you could post up your experience with ITM Uni-Sensors, it would be very helpful.
FYI> I have 18inch wheels on all four corners (Ace Alloy Slick wheels) and will be putting on the Continental Tires ExtremeContact DWs, 265/35/18 up front and 295/35/18 and the back.
Goose
Goose
TPMS> ITM Uni-Sensors ’97, ’98, ’99 Owners Chime In
Getting ready to put on some new tires >“meats”< on the ride and going to swap out the TPMS’s while the meats are off the wheels. As I have a 1999, finding fresh (batteries) OEM TPMS’s is very difficult. Additionally, I do not want to swap out the receiver, TPMS’s and fobs as I do enjoy the features the ’99 Fobs.
I’m looking at a set of ITM Uni-Sensors and as I understand, you can NOT use the standard DIC tire training method (with large magnet) to train these ITM Uni-Sensors to each wheel.
Did the tire shop “clone” your replacement sensors from your original sensors?
FYI> I have 18inch wheels on all four corners (Ace Alloy Slick wheels) and will be putting on the Continental Tires ExtremeContact DW’s, 265/35/18 up front and 295/35/18 and the back.
Goose
Goose
I do have the ITM sensors on my ride and they work perfectly!!!. Although I have these ITM's installed on all 4 wheels the training of these sensors is different than the OEM sensors.
The sensor difference is as follows;
The OEM sensor needs a magnet placed next to the valve stem to activate or train to the car/wheel position.
The ITM sensor uses "rapid" air pressure change to train to the car/wheel position, (NOTE the magnet will not work with the ITM sensor).
During my ITM training, I aired up the tires to 35 psi and activated the training in the DIC then rapidly deflated each tire after the horn beep. when all was said and done, my tires had about 15psi left in each tire which then was inflated to correct pressure.
One more comment, the car's learning mode does not allow for a "slow wheel learning" process, basically you need to move quickly to the next tire after the horn beep.
As I weigh 2 bills plus...I could not move around the car quick enough to deflate all 4 tires to complete the learning process and what I did was put the car up on tri-pods, removed all 4 wheels and tires, laid them in a row next to the car, activated learning process, LF tire, beep> RF tire beep>RR tire beep>
then reinstalled the wheels and tires, all is good now.
hope this helps.
Kevin
The following 2 users liked this post by 69:
buckeye1872 (01-07-2016),
Droberts (01-07-2016)
Here is the questions that I PM'd to Kevin,
Thanks for the reply Kevin,
That's good info. I'll just have to try learning my OEM/ITM sensor combo to see if it will work. I'm going to try using a magnet on the OEM and letting the air out of the RR where the ITM-Uni is. I will be supprised if it works.
I got shafted by Tire Discounters here in Cincinnati when I took my RR wheel in for a repair. The OEM TPMS actually came loose and fell into the tire. The sensor was still good, but they replaced it with the ITM-Uni and the OEM was trashed. When I went back with the Vette they blamed weak batteries in the OEMs for their not being able to activate the sensors, but the system was working fine before. It was obvious they were clueless as to what to do.
Now I have to decide weather to get three more ITM's or send in a set of OEMs I have for battery replacement when I get tires in a few months. I'm leaning toward using the OEMs since they are easier to learn.
Anyway, thanks for your help.
I would look into the upgrade to newer parts. I have a 97 and have been looking around. You can find a newer receiver for $50 on eBay. Then 2 key fobs are $25 on amazon . Then tpms are like $30 a piece . You can do the whole change over $200 if you shop smart.
Droberts (01-09-2016)
Thanks, are the key fobs necessary to do the TPMS upgrade?
St. Jude Donor '15
https://www.corvetteforum.com/forums...post1590682328
Bought these off ebay and have no issues with them
Success learning combo of OEM and ITM Sensors
