Transmission broke after fluid change !!
Old 12-03-2013, 02:54 AM
Mohammed_z
Mohammed_z's Avatar
Default Transmission broke after fluid change !!
A friend owns a C5.
Changed the trans fluid. And the day after the transmission acts crazy.
it acts like slipping clutch in manual transmission and then it wont shift to 4th. and sometimes to 3rd. Then tranmission high temp message appeared.
Some say , changing the fluid will cause this. But I don't agree since changing fluids is a routine maintenance in the owners manual.
The main question is , what cause transmission failure after fluid change ?
choosing the wrong oil ?
using the old fluid ?
using the same filter ?
other than that ?
Old 12-03-2013, 03:05 AM
ZeeOSix
ZeeOSix's Avatar
Did he use the correct auto transmission fluid? If so, I can't imaging changing the fluid would hurt the transmission unless he under filled it and it burned up the clutches.
Old 12-03-2013, 05:55 AM
Mohammed_z
Mohammed_z's Avatar
Thats what I was telling him, either under filled or wrong fluid !
Old 12-03-2013, 10:09 AM
Dcollins3208
Dcollins3208's Avatar
I'd assume under fill. After an initial fill, he should have turned on the engine, let trans temp reach somewhere within the 80-120 ball park, shift through all gears, shift back to park and top off. Just did it recently while installing trans cooler.
Old 12-03-2013, 10:29 AM
Clyde2
Clyde2's Avatar
It's been my experience that most times people don't change the fluid and filter in the transmission as a maintenance thing... Usually they were having a problem before the service, always test drive to verify a problem or just maintenance .
Old 12-03-2013, 10:58 PM
Mohammed_z
Mohammed_z's Avatar
Good point !!
Old 12-03-2013, 11:10 PM
C5Natie
C5Natie's Avatar
You'd be surprised how interchangeable these atf fluids are so I would say he underfilled it or maybe theres an obstruction somewhere. Also I always change the filter when I service the trans. The corvette filter has a long tube under it to suck up fluid. The regular filter for a 4L60E does not. This can also cause the trans to starve for fluid.
Old 12-04-2013, 10:02 AM
TEXHAWK0
TEXHAWK0's Avatar
How many miles since the fluid had been changed, if ever?
Sometimes if you wait too long, then fresh fluid can free up deposits and cause an obstruction in a passage.
Old 12-04-2013, 11:37 AM
dankhts
dankhts's Avatar
big time! if the fluid is dark, burnt, thick, has a lot of clutch material floating around in it, never been changed etc, best to leave it alone or it'll likely cause a failure quicker by changing it! Hopefully though it's just down a bit....
Old 12-04-2013, 12:12 PM
Bluefire
Bluefire's Avatar
Re-check the fluid level. The service manual strictly states that the fluid temp MUST be between 86F - 122F when doing a level check.
I checked mine when it was hot and it was "full". I then waited until it cooled to the proper temp and I found I was 22 oz. low.
HTH
Old 12-04-2013, 02:28 PM
jim993
jim993's Avatar
There have also been reports of new filters that are not vacuum tight. A vacuum leak in the filter will starve the transmission of fluid.
A new filter should be vacuum checked before installation by sucking on the round tube that goes into the transmission while at the same time sealing the oval filter inlet with the palm of your hand. A good filter will hold this vacuum.
Old 12-04-2013, 06:02 PM
OneFast1
Support Corvetteforum!
OneFast1's Avatar
Originally Posted by Mohammed_z
A friend owns a C5.
other than that ?
Could it be an improper filter install? It reads as though the transmission is starving for fluid. Assuming that fluid level is correct, I would pull the pan to be sure the filter is tight and not pulling air. If the filter was not changed, could it have been hit or jarred?
Old 12-04-2013, 07:56 PM
jim993
jim993's Avatar
The fluid level must be checked with the engine RUNNING. Transmission in park.
Old 12-04-2013, 09:07 PM
bracketshark
bracketshark's Avatar
I'd bet the wrong filter is installed.
Old 12-04-2013, 09:43 PM
reactor2
reactor2's Avatar
My uncle owned a small local courier company that owned several Chevrolet vans, equipped with TH350s. They found that if they did not change the transmission fluid ever, the transmissions would last the entire service life of the vehicle. However, if they changed the fluid (I think it was around 100k miles) the transmissions would fail within 5k miles. It happened frequently enough to make them change their policy.
Old 12-05-2013, 05:26 AM
Mohammed_z
Mohammed_z's Avatar
I think putting new oil and let it drain again will take away those deposits !?
This is weird !
Then why there is a fluid change service !!
Old 12-05-2013, 09:46 AM
Evil-Twin
Evil-Twin's Avatar
Received 3,812 Likes on 1,925 Posts
St. Jude Donor '03-'04
something was wrong before the fluid change that prompted the owner to change the fluid, or the wrong fluid was used. or it was an error in the correct fill capacity.
Old 12-07-2013, 07:35 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
most change due to a problem and of course blame fresh fluid for the problem.
Keep the trans fluid serviced dont buyi into that 'good for 100k' bs like I did. It costs
Old 12-07-2013, 08:16 AM
Dave02C5
Dave02C5's Avatar
in autos i'd drop the pan every 30-40k. never a problem here. either the trans is roached or the fluid is low and by having low fluid and having intermittent pressure on the bands, probably roached it as well.
douglasjre (01-17-2023)
To Transmission broke after fluid change !!
Quick Reply: Transmission broke after fluid change !!
