Done gone crazy???
Done gone crazy???
The headlights on my 02 Z are going crazy. Today I turned on the lamps and could not get the doors to close all the way when I turned them off. I cycled the switch several times to no avail....they seem to close about 1/2 way and stop. I then manually closed the doors and all seemed well. When I fired the car back up, the doors opened automatically even though the headlamp switch was in the off position??? Every time I manually closed the doors, they automatically go to the open position when I cycle the key to the on position....the lamps are not on unless the switch is in the on position. What might be causing this issue?
Don't think that's a gear issue, but I may be wrong. I think the cause of the lights opening upon start without the switch being used is due to the Headlight Control Module being bad. Mine did that too. Replaced it and no issue.
Although I have to ask, because a buddy had similar problems, do you have HID's? When you start messin with HIDs without the proper functioning resister your headlights flip out. Just my 2 cents
Received 2,182 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The headlight assembly opens and closes via the headlight control module. It senses a specific TORQUE applied to the motor when the headlight module hits the stops. There are white plastic stops in the assembly that need to be in good shape for proper operation
When the headlight module hits the stop, the motor torques and draws additional current. The headlight control module senses that current draw and stops driving the motor.
If your module is bad, it will fail to drive the headlight properly.
Remove the control module and examine the back of it and see if it has separated allowing moisture to get in.
Bill
Bill
I did receive a resistor with the kit, just no instructions of where to put it. Do you happen to know, or can you find out, where your buddy put his resistor?
PLEASE AND THANK YOU!
Bill
Bill
Ok, next question I have for you is where you bought it, these resistor are quite cheaply made and the only place that we found that worked was that JW motors(or something like that). We put his on the driver side after like the 3rd resistor we tried and had not had a problem yet! Hope that helps
If you bought a cheapo HID kit, then that's your problem right there. Don't chase your tail trying other possible causes, especially since this starting occuring after you installed them. Either find the instructions and install them correctly with the resistor or buy a better kit that comes complete. If you could shed some light on what kit you bought that might help others to get you fixed.
Check your bump stops, those white plastic things inside the light housings. This sounds like the common problem on here referred to in multiple threads (search is your friend, even though the one on here is not very good). My car had the exact same problem and it was cured with new bump stops bought from a forum vendor on here. Try to solve the simple things that go wrong before looking for more complicated solutions.
