Service Traction Control message and tires
I recently purchased an 01 C5. Love the car. The "service traction control" light has been on since I purchased the car. I knew going into it. I check the codes and there where many. I reset the codes and the first 2 that came up were c12287 and c12288 which indicates the steering sensor is a problem.
The current tires are 285/40/18 and 255/45/17. This size change from stock has only a very slight difference in diameter stagger. I calculated the stock setup at .98" difference and the new at .94" difference.
I spoke with a trusted tire store and they said you need to get them back to stock size.
Agree or change the steering sensor first?
8th Gear
I've had my 2001 Z06 for nearly 2 trouble free years. Done various upgrades without hitch and I love the car...it's great. However, recently I have 2 codes recurring , C1288H and U1064H. They occur simultaneously. The driver info shows 'service vehicle and also active handling' messages.
I know that C1288H is a steering monitor issue. Am I correct in assuming that U1064H is coming up because of the fault there is a failure to communicate info? I've tried cycling the steering through about 50 cycles in an effort to 'clean' the monitor, but no joy.
Before I conduct 'major surgery' I have some questions. It was immediately before this issue that I fitted a B&M shifter. This of course required removal and disconnection of the active handling button and now (coincidently?) I have this problem. I've done the obvious and rechecked the connection to the button, but to no avail. Could it be this? Have I triggered something? Any bright ideas?
8th Gear
Yes thanks for the response Ace 147. I was pretty sure that was the problem but raised the other points just in case I was missing a trick.
I've now fitted a new steering position sensor. Not technically challenging, but just a bit awkward. .......Road tested the car really hard and everything seems 100% perfect now. Phew!!
