Service traction control
Old 09-16-2013, 02:31 PM
AllanE
Navigator
AllanE's Avatar
Default Service traction control
Hey all,
For a while now, every so often when I turn my 01 corvette on I get a message saying service traction control/abs. Was wondering if anyone can help me with getting rid of it?
Old 09-16-2013, 02:44 PM
wbrands
Support Corvetteforum!
wbrands's Avatar
I'm having the same issue intermittently on my '01, getting code C1214 I think (you should pull yours and see what you're getting). I have decided I'm having the EBCM failure that appears to be fairly common in these cars. Can be very expensive (north of $1,000) at stealership to remove and replace to a couple hundred to send it to ABS Fixer for repair, to time and effort as noted in the link below. Check it out at:
http://forums.corvetteforum.com/c5-t...r-fleabay.html
Old 09-16-2013, 03:17 PM
xzo124
xzo124's Avatar
Originally Posted by AllanE
Hey all,
Yep , check your codes .. Mine turned out to be Front wheel speed sensors. Did both of mine for $316.00 Autozone Lifetime parts....xzo
Old 09-16-2013, 03:48 PM
AllanE
Navigator
AllanE's Avatar
Alright I cleared all my codes
on my TCS I have 1 code that I can't get rid of
C1214 H C
Where do I go from here?
Old 09-16-2013, 04:36 PM
BigGun
BigGun's Avatar
C1214 H C
Check the link in post #2. Good information! Your ebcm needs to be replaced or fixed. Having it fixed is a much better option price wise. Pull the module or pay someone to remove it for you and send it to one of the many abs fixers listed on e-bay.
Old 09-16-2013, 05:10 PM
guido7834
guido7834's Avatar
Check the sensors at the wheels. I had the same intermittent issue and cleaned the connectors and it hasn't happened since. Just an idea.
To Service traction control
Quick Reply: Service traction control
