Best place to buy Fast 92?
As the title says Im looking for the best place to buy a fast 92, most likely to be paired with a Ls2 throttle body. Both of them being ported. I already have a set of AI ported 243 heads milled to 60CC, I still havent picked out a cam however I was looking at a 226/234-113 .600” cam. From what I understand its a fairly mild cam good for mid 400's. I would like to get close to 500, its not a daily driver so Im not too worried about going with an aggressive cam I just dont want to cut reliefs in the pistons. So if anyone has any recommendations on a cam that would be awesome too.
Its an 02 z if that matters and the drive train has already been beefed up.
http://vengeanceracing.net/index.php...gines-232.html
Right here, they'll port your intake and throttle body and provide the adapter too so you can just order all from one place instead of all separately.
Received 2,061 Likes
What size valves and head gaskets? I would run a larger cam with more lift if looking for max hp, you're leaving ~15hp on the table with that cam over our V4 cam and plenty of guys daily drive it. Few 346 have hit an honest 500rwhp SAE and they come with a lot of attention to detail.
