Goodyear Gatorback Poly-V Serpentine Belts?
Old 09-05-2013, 07:30 PM
97VetteDan
97VetteDan's Avatar
Default Goodyear Gatorback Poly-V Serpentine Belts?
I can't seem to find any Goodyear Gatorback Poly-V Serpentine Belts for my 1997 Corvette. Everyone I've talked to says they have been discontinued...
I believe the part numbers to be 4060802 for the main drive, and 4040420 for the AC drive. Can someone point me to where I might be able to find some? Thanks.
Old 09-05-2013, 08:25 PM
racebum
racebum's Avatar
that's not at all the case. i just ordered goodyear belts from amazon
rock auto also often has them
if for some insane reason you can't find them dayco also makes a poly belt with a similar non squeal material
Old 09-05-2013, 11:58 PM
97VetteDan
97VetteDan's Avatar
Thanks man! Ordered them from Amazon.
Old 09-06-2013, 02:33 AM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
Amazon FTW.
Old 09-06-2013, 08:32 AM
leadfoot4
leadfoot4's Avatar
Received 1,343 Likes on 1,094 Posts
How about the new Gates Racing serpentine belts? They're BLUE!!
Old 09-06-2013, 08:27 PM
RedZMonte
RedZMonte's Avatar
Looked on gates site, only lists the AC belt in the "Racing belt"... Bit ironic seing how most race cars remove the AC
http://www.gatesracing.com/parts.aspx
A.C. High Performance Automotive V-Ribbed Belt K040420RB (Blue)
Serpentine - Accessory Drive Automotive V-Ribbed Belt (Standard) K060802
Advanced Construction
- High-modulus, low-stretch polyester tensile cord with the strength to transmit load more accurately with less vibration
- Advanced belt profile that is precision ground for an exact fit
- Strict adhesion to OEM dimension specifications, eradicating slip noise and accessory belt drive wear
Innovative Materials
- Specially engineered adhesion layer offering extended service life
- Durable overcord made from heat-resisting polyester fabric
- Undercord reinforced with heat-resistant and strong aramid fiber technology
Distinctive Appearance
- Signature style and customized look with an expanded product line and new color selections
Old 09-07-2013, 01:37 AM
LoneStarFRC
Hmm, I went to the site you linked and plugged in my application and it shows both belts in the blue racing variety.
The six rib main belt shows:
Serpentine - Accessory Drive High Performance Automotive V-Ribbed Belt K060798RB (Blue)
Old 10-14-2013, 05:39 PM
neilvosko
neilvosko's Avatar
had my AC belt incinerate on the WAY to the track this weekend....so looking to replace both AC and serpentine with the GATES racing line....will post feedback
Old 10-15-2013, 02:53 PM
racebum
racebum's Avatar
i'm sure they will work great, you just could have bought what? 3 goodyears for each gates blue?
To Goodyear Gatorback Poly-V Serpentine Belts?
Quick Reply: Goodyear Gatorback Poly-V Serpentine Belts?
