Battery died now car won't crank
Old 04-16-2014, 09:37 PM
Oklahoma Adam
Oklahoma Adam's Avatar
Default Battery died now car won't crank
Here's the deal I went to drive the car the other day and the battery was low and after a couple of slow cranks and a few starter clicks I gave up. The next day I put the charger on it and turn the key and no crank, everything lights up like it should but then nothing. So I think maybe the battery is shot and go get a brand new battery. With new battery, still won't crank. I had this problem last year and it was the ignition switch vats thing. I replaced it and that solved the problem. Could that have worn out again? I'm stuck, here are the codes.
BCM
B2587 H
B2592 H
LDCM
B2282 H
B2284 H
U1096 H
RDCM
B2283 H
B2285 H
Please HELP
Old 04-16-2014, 09:57 PM
Oklahoma Adam
----------------Update------------------
Looks like the starter solenoid is broken. Not sure how that happened but the hot wire moves around and the nut is still tight. New question. Can the starter be removed with long tube headers in place?
Old 04-21-2014, 04:51 PM
Oklahoma Adam
--------Update 2---------
According to the shop you cannot remove the starter without removing the header.
Old 04-21-2014, 06:14 PM
Chicago1
Chicago1's Avatar
http://forums.corvetteforum.com/c5-f...h-headers.html
To Battery died now car won't crank
Quick Reply: Battery died now car won't crank
