What spark plugs to buy?
1 Post
It's time for new plugs.....81k miles on the clock of my '98 coupe.
I've been hearing about a new or newer AC/Delco Iridium plug. Does anyone know the GM part number? I'm not a racer, just a cruiser that like likes long road trips, so just looking for longevity and better gas mileage. I hear the new Iridium plug is the best to now use but the part number may be different from the plugs offered a year ago. Does anyone know for sure?
Thanks!!!!!
Thanks!!!!!
While the price on iridium/platinum has come down recently so it isn't a ripoff as much anymore, I still run copper. Most tuners recommend NGK TR55. Platinium/iridium and getting power/gas mileage increases are marketing gimmicks.
You might get more longevity out of an iridum plug, but for Vette owners who normally want the best performance, taking an hour to change plugs every 25k miles shouldn't be an issue.
1 Post
I just put a set of NGK Iridium IX TR 51-X in my 99. You can get them at Rock Auto for $51.84. Might as well think about changing your wires also, I changed mine from 7mm to MSD 8.5. Very noticeable difference in idle and acceleration. JMHO
GM Service Manual for my 99 calls for .060 plug gap. Pulled all my plugs for header install and they are all about .066 with 70K miles on them.
That number has since been revised by GM to a smaller value. If NGK, the TR5 would be the plug to use rather than the TR55. The second 5 in the part number denotes a wider gap.
However, I'll throw in my $0.02 worth..... Bosch Platinum +4s in my car.
Replaced my 98 platinium with Iridium and new Red Wires
As I remember the Iridiums are gapped differently the the old platiniums.
I also went with the Red GM Wires that are half the cost of the black ones. That was about 40K miles ago. Still going strong.
My new Iridiums were slightly misgapped. Coating is thin that is why they say don't regap them. If you take your time and stay away from the real gap between the electrodes you are fine. Just don't scrape the Iridium off of the electrodes.
