2000 corvette fuel tank pressure sensor location
I assume you mean the fuel pressure regulator??? I'm unaware of anything called a fuel tank pressure sensor on any C5.
If that is what you mean then the pressure regulator function is performed by the fuel filter for 1999 - 2002 and the early 2003 vehicles. In Mid year 2003 GM switched the fuel system to RPO FFS and the fuel pressure regulator is in the tank and is a part of the fuel pump. On the 1997 - 1998 C5's the fuel pressure regulator was located on the intake manifold.
46 - GRAY - Fuel Tank Pressure Sensor 5V Reference
its labeled on the pcm as pin 46 on the blue connector, I just need to find it.
Looks to be on LH side of car near, or at the top of, the fuel tank. Looks like it is held/retained by a small bracket and a hose connects to it. A three-wire plug connects to it. NOTE: this pic does not show ALL the hoses/components etc, for the fuel system, and is only one of two or three illustrations.
Edit: Found this photo. You can see the sensor with a 90* elbow hose/tube attached to it sitting above the other two hoses by itself. That picture is of a '99 and from what I can find, I'm pretty sure the 2000 is the same.
HTH
At least you know what it looks like now and be able to spot it easier.
HTH
I know this is almost a year old but I am curious as to where it is at on a 2001 I am having problems with my fuel pressure dropping off hard when it's hot out and the car is warm
http://forums.corvetteforum.com/c5-f...post1587404670
edit: I looked it up but mine does not look the same..it's a 2001 I will have to see where it is on mine.
Mine doesn't look like the one above at all...
Someone helped me out, so I'll try to pay it forward.
After 99/00 the C5 was changed to a return-less fuel system, That MAY* explain why yours is different.
Edit: As a suggestion, you may want to post in the help section for your issue. Might be something common, like a crack in the tank once it expands slightly (since it does it once warm). On some cars the issue you described is caused by an old gas cap, resulting in a poor seal.
