whats the best injector to buy.
Fully built my c5 383 stroker. Ls6 ported heads huge cam. Fast 102 intake nw102 throttle body.. a&a 4in intake pipe to 102 maf to air filter. 4200 stall. 411 gears. Long tube headers. No cats with corsa mufflers n exhaust. Ls6 water n oil pump. Fast fuel rails holley valve covers.. etc. Tuner said Ima need 55# injectors. what's yal opinion and what is best brand to get?
I got Injector Dynamics for my H/C/I build. Pricey, but they come with all characteristic data to give your tuner all the data he possibly needs to get the most of out of your build.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I agree with "Must_Have_Z" in that what ever injectors you get, the characteristic data is very important and needs to be adjusted into your tune!
BC
I have a pretty beefed up 5.7 02 ZO6 (pretty close to your bolt ons) and I have 42s. If your tuner says 55s, that most likely what you need. Mine is the stock bore and stroke but has a BIG cam and ported 11.1 heads, ported FAST 90, vararam, stainless works headers wit 3" mid pipe and cat back.
BC
BC
also.. does anyone kno what hood is used for ppl running a A&A kit with the 4" pipe from tb to intercooler? Stock hood wont fit.. may cut...
