Noisey cats...Replace them or lose them?
I was very interested in the magnaflow offroad H pipe until I read they were actually causing issues and a smaller diameter then stock? Mines got 130k on the oem cats, no codes but has a weird odor. Will you lose any hp due to the 2.5" magnaflow H pipe compared to the stock 2.75" with cats? Also if you get rid of the cats the car will need a retune and will run rich with a check engine light correct?
I would like to keep my stock 97 manifolds without the pup cats, and planned on purchasing this until i read they are smaller diameter then stock. Would I be better off somehow gutting the stock cats, i'd hate to have a shop do a hackjob on the exhaust and just cut them out. Also with that check engine light on will it be pulling timing or anything that will rob horsepower as well?
I am also seeing that Bassani makes some catless x pipes, but I am having trouble finding them for sale. Also noticed the "test pipe" section only says 2.5" as well. If I were to go catless without hacking the system would the catless X pipe be the way to go, or should I get the catless H pipe. I just read the stock H pipes are only 2.5" anyways? I'm getting confused....
Well, I found a stock mid pipe with cats...might add an x pipe later, but keeping it factory other than my axle-back for now. Hopefully swapping out a stock mid-pipe for another stock mid-pipe is something I can do in my garage.
