Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-01-2013, 02:17 AM   #1
seansz28
CF Senior Member
Default rear diff blew up..need thoughts
Click the image to open in full size.
this happened after doing a small burnout that had some wheel hop in it . then after stopping will not move in any gear it just acts like its in neutral, also the trans feels like its shifting normally. the wheels both spin the same direction when rotated in the air im looking for opinions on what exactly broke besides the diff carrier to cause the tt and the diff to not connect
seansz28 is offline   Reply With Quote
Old 08-01-2013, 09:12 AM   #2
alextz
CF Senior Member
Broken transmission output shaft is what I bet
alextz is offline   Reply With Quote
Old 08-01-2013, 09:34 AM   #3
bumble-z
CF Senior Member
Broken trans tail shaft or differential short axle.... really doesn't matter.
Once you pull the differential out, will tell if it's either of the two.
You really are a prime candidate for a differential/trans brace to help prevent the trans or differential cases from cracking/breaking.
http://www.eastcoastsupercharging.co...ategory_id=152
http://forums.corvetteforum.com/1584469995-post1.html
http://forums.corvetteforum.com/1584511592-post1.html
bumble-z is offline   Reply With Quote
Reload this Page rear diff blew up..need thoughts
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
More recent c5 diff into 05c6 write up? Bryanthehunter C6 Tech/Performance 1 03-17-2014 07:08 PM
E-diff predictiblity in Autocross, rev match continuity, real life colo thread? Metalgearsolid_x C7 General Discussion 38 11-12-2013 04:42 PM
DIY diff cooler? moespeeds Autocrossing & Roadracing 5 09-03-2013 04:51 PM
How much PITA is Diff crossmember AirborneSilva C3 General 10 02-01-2013 01:34 PM
C-Beam elimination options?? msm vett C4 Tech/Performance 17 11-21-2012 12:30 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
