Cooling Fan Manual Override walkthrough?
2016 C5 of the Year Finalist
St. Jude Donor '12, '14
Hi,
I've done a search, but haven't been able to find a good walkthrough for installing a toggle switch to manually control the cooling fans. As I get more into tracking the car, I would like to keep the fans running constantly at the track. Has anyone done this mod? I'm a noob when it comes to the electrical system and could use all the help I can get! Thanks!!!
back when I had a 94 firebird formula(lt1), mounted a toggle switch under the dash, ran two wires to the fuse box in engine compartment and jumped across two connections to be able to turn fans on. don`t remember which two connections, but worked great, esp in stop and go traffic. don`t know if you could do it with a vette, cost less than $5
