C6 rims on a c5
C6 rims on a c5
Hi there,
I know this has probably been asked lots of times but I searched and couldn't find anything on this.
I'm looking to put these OEM c6 5 spoke 18/19s on my car but the rear tires are worn. I'm was wondering if I can put a 305 30 19 on the rear and leave the front 245 40 18 as they still have a good 60ish% left. I want to make sure I wont get any error messages/active handling problems. Whats the best rear tire size to use?
Also does anyone know what spacers will make the wheels flush with my fenders? Thanks
St. Jude Donor '12-'13-'14-'15-'16
Good question, I am thinking about buying the 305 for the rear. I have 245 in front. That is only .48 difference in diameter, they say you need .50. Will .48 be ok?
245/40R18
Section Width: 9.65 in 245.00 mm
Rim Diameter: 18 in 457.2 mm
Rim Width Range: 8 - 9.5 in
Overall Diameter: 25.72 in 653.20 mm
305/30R19 Section Width: 12.01 in 305.00 mm
Rim Diameter: 19 in 482.6 mm
Rim Width Range: 10.5 - 11.5 in
Overall Diameter: 26.20 in 665.60 mm
245/40R18
245/40R18
245/40R18
245/40R18
245/40R18
There's really no definitive answer here. In my opinion, you're cutting it too close.
