Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-30-2013, 01:42 PM   #1
MIAmotorsports
CF Senior Member
Default What gear lube for a whining set of gears
I was wondering what gear lube you would recommend for a rear that has some gear whine. I was looking at AMS and was wondering what kind of luck you had with the road race/drag race lube.
MIAmotorsports is offline   Reply With Quote
Old 07-30-2013, 03:46 PM   #2
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Support Corvetteforum!
Bill Curlee's Avatar
Gear lube is most likely NOT going to fix a rear end gear whine. The gear noise is mostly always the result of an impropery set up ring and pinion or damaged ring/pinion tooth faces (scoring)
You can change the lubricant but, i seriously doubt that it will eliminate it. Check with AMSOIL. They have a very good 75/90 weight oil with the correct limited slip addative.
BC
Bill Curlee is offline   Reply With Quote
Old 07-30-2013, 03:55 PM   #3
MIAmotorsports
CF Senior Member
I am not trying to fix it but quiet it down some. Even a little is better than nothing. It is an RPM stage 4 rear. A year old and dont want to rebuild again. I know some people say royal purple for gear noise and some aims posi additive
Old 07-30-2013, 04:57 PM   #4
mchicia1
CF Senior Member
Gear lube isn't gonna do anything. I tried thicker lube once for a whining diff and it got louder if anything.
mchicia1 is offline   Reply With Quote
Old 07-30-2013, 08:18 PM   #5
DTE Performance
Supporting Vendor
DTE Performance's Avatar
Different or new gear lube will not correct or reduce gear noise. However the wrong lube can create it. A Corvette differential utilizes hypoid gearing meaning the pinion is offset from the centerline of the ring gear. This makes for a stronger gear-set but introduces a sliding component. As a result gear lubes used in hypoid gearing must contain an EP (extreme pressure) additive. Most commercial oils today do have the EP additive however if they don't the results are scoring and noise. When in doubt check.
DTE Performance is online now   Reply With Quote
Old 07-30-2013, 08:20 PM   #6
C66 Racing
Premium Supporting Vendor
C66 Racing's Avatar
This is the appropriate fluid, but don't think any fluid will help the noise:
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 (Product Code SVGQT)
I had an 06 CTS-V for several years (sold it in 09) and that model had many TSBs on diff whine. Many Caddy Forum members tried heavier weight fluid (e.g. 75w110) but I never saw consensus that this really helped and the increased viscosity would result in a loss of net HP and a lowering of mpg.
__________________
C66 Racing #66 SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
C66 Racing is offline   Reply With Quote
Old 08-01-2013, 10:23 AM   #7
StrangelovesM6Vert
CF Senior Member
StrangelovesM6Vert's Avatar
If lower noise is more important than losing a few hp then add some Lucas oil additive.
It's thick like honey and will absorb some of the noise.
You could also wrap some kind of insulation around the pumpkin and leave just 1 face for cooling if you're not beating on it all the time.
All together this may reduce your noise by half but won't eliminate it.
StrangelovesM6Vert is offline   Reply With Quote
Reload this Page What gear lube for a whining set of gears
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
