Rear spring upgrade
I just finished doing this a few weeks ago and it made an immediate difference on my FRC. I love it so far. I'm ordering Pfadt mounts and their JOC Stage 1 kit next week to go along with it
Made a definite (positive) difference in handling.
I was going to get an alignment after I install my JOC Stage 1 Package and Pfadt Motor and Tranny mounts next week. I lowered my car max on stock bolts when doing the spring so I guess I'm in the settling stage right now?? Lol I like the height that lowering on stock bolts gave me, I didn't cut any bushings up front or put in longer bolts in the back, I just adjusted my bolts until it dropped it as far as it would go without cutting anything or putting in new bolts. I have about an inch or so of gap now between tire and fender
I installed a set of Z06 font and rear springs and the JOC Stage 1, about a week ago and aligned it to PFADT specs. I have about 200 miles on it so far.
WHAT A DIFFERENCE. I love the firmer ride. The car now feels completely different (in a very positive way). I did start hearing more creaking/squeaking in the interior from the panels moving around a bit more. Nothing some additional chassis support won't fix.
Do the Z springs and don't look back.
St. Jude Donor '13-'14-'15
I guess the Z06 springs are meaner than what you have-- Stiffer springs will give you a harsher ride---The benefit of stiffer springs (IMHO) work only at higher speed like over 100 MPH--they make the car ride flatter around the curves---The drawback is that while driving around town and even at high way speeds the rear of the car will tend to "hop over the bumps rather than to drive over them--Even going over the reflectors in the road --the car will hop over them--If that doesn't bother you then go for it--Another option would to install a larger rear sway-bar and poly bushings--They would make the car run flatter in the corners but still retain the softer ride during normal driving--
Too many people forget that tires are part of the suspension/handling, etc along with shocks/springs/bars.
Ever notice the OEM Z06 cars HAD no run crap tires from the factory? Losing the runcrap tires was one of the best decisions I ever made.
From what research I've done on the matter: For '00+ Z51 cars, they have the same front bar and spring as the '01-'04 Z06. The Z06 rear spring is stiffer than the Z51, but the rear bar is softer. In '04, the Z06 got the Z51 rear bar, and has the firmest factory setup of all C5s (stiffest springs, stiffest bars, and shocks to match).
my $.02
my $.02
My personal experience with a number of newer Vettes suggest that the base springs work best in my street cars. I just picked a base 01' vert with the base springs, slapped on a huge set of sway bars and have the best of both worlds. A great ride on less-than-perfect roads and much better handling.
stock sprung and those with stiffer springs and those with simply larger sway bars and poly bushing------My opinion ??? The best is to go the sway bar route---unless you are driving a dedicated "race car"
stiffer springs ????? make an appointment with your dentist to get your fillings replaced---LOL
You guys are a bit dramatic about these z06 springs. They're not THAT bad, my suspension still work as it should, I don't "hop" over bumps, I still have a nice ride, it just handles and takes corners more comfortably. It's stiffer yeah, but it's not the cement truck ride that you guys are making it out to be.
