Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-04-2013, 09:05 PM   #1
bliehr
CF Senior Member
Default Climate control shutting down.
Hay guys
Havenít posted here in awhile but I need your help again with my AC.
I have a 97 with Climate control and out of the blue it has started shutting down, and on its own, comes back on in 2 to 10 minutes. It doesnít seem to matter if I am driving or itís sitting in the driveway idling.
Is there a circuit breaker somewhere that may be going bad?
Itís 90+ degrees here in PA and I need that darn AC to work.
Any help will be greatly appreciated.
bliehr is offline   Reply With Quote
Old 07-04-2013, 10:07 PM   #2
8VETTE7
CF Senior Member
8VETTE7's Avatar
I would have the freon in the system checked. Low freon can cause the system to shut down/cycle.
No circuit breakers in the AC wiring. Fuse 24 and relay 34 both in the engine compartment fuse box.
Also fuses 18 and 27 in the IP Fuse box behind the toe kick in the passenger foot well.
8VETTE7 is offline   Reply With Quote
Old 07-04-2013, 11:15 PM   #3
bliehr
CF Senior Member
Freon is good with plenty of cold air. That was the first thing I checked and pressure on low side is good.
Thanks for the reply
Old 07-05-2013, 12:33 PM   #4
jcgunn
CF Senior Member
jcgunn's Avatar
Is your OAT gage reading correctly? If the sensor is bad/disconnected and the system thinks the OAT is cold, it won't let the A/C stay on.
jcgunn is offline   Reply With Quote
Old 07-05-2013, 08:00 PM   #5
bliehr
CF Senior Member
Thank you for your reply.
My entire climate control system shuts down and the screen goes blank as if there is no power going to it.
It is not JUST an AC problem, even the defrost will not come on.
BTW, what is an OAT gauge?
Old 07-05-2013, 08:12 PM   #6
TEXHAWK0
CF Senior Member
TEXHAWK0's Avatar
I think he is talking about the Outside Air Temp. sensor. If it is outside the temp. range, it will cause the compressor to shut off, but don't think it would power down the AC control head.
You may just need to have the control head checked. There are places on Ebay that will sell you a reconditioned control head, including making sure all the lights work...
By the way, it is a common problem for the display resistors to come loose from the circuit board and cause the display to go dim, or off... That could be the problem if just the display is dim, and the controls still work...
TEXHAWK0 is offline   Reply With Quote
Old 07-06-2013, 03:16 PM   #7
bliehr
CF Senior Member
No, the controls wont work either. Then after a few minutes it will all come back on for a wile and then off again.
Old 07-08-2013, 07:31 AM   #8
jvette2
CF Senior Member
Send a message via AIM to jvette2
I have been having the same issue with my controls for the last couple of summers. Some times it works and then some times it does not.
jvette2 is offline   Reply With Quote
Old 07-08-2013, 06:06 PM   #9
bliehr
CF Senior Member
Well now I'm thinking a bad ground somewhere, but where to start??
If it ever cools off a little here in PA I'll take a look and see if I find anything.
Old 07-17-2013, 04:11 PM   #10
bliehr
CF Senior Member
Can anyone tell me where the ground wire may be for the Climate Control unit?
Old 07-22-2013, 09:43 PM   #11
bliehr
CF Senior Member
Can anyone help me out? I know someone out there can get me started on the right track and I will be most grateful.
Reload this Page Climate control shutting down.
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
AC light on rwobs777 C5 General 12 11-20-2013 09:01 PM
89 C4 Climate control revets00 C4 General Discussion 6 05-04-2013 01:53 PM
My climate system on my 92 has stopped working mixalive C4 Tech/Performance 9 02-04-2013 09:47 AM
93 LT1 Shuts Down While Driving zilla24 C4 Tech/Performance 19 12-24-2012 11:16 AM
Heating/Cooling issue Stinngray C5 General 0 11-02-2012 06:26 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
