LED light issue
Old 06-27-2013, 02:49 PM
jamieo
jamieo's Avatar
Default LED light issue
Just replaced my rear view mirror and installed LED lights in it while I had it apart.Now when I use the light switch on the mirror,the light is really dim.Checked with a DVM and it only shows about 6 volts.When I open the door or use the interior light switch they light up like they are supposed to.Anyone else ever have this issue?What could I be overlooking?Thanks for any suggestions!
Old 06-29-2013, 08:26 AM
Gilligan3
5th Gear
Gilligan3's Avatar
Default Rearview mirror
I don't have an answer for U but I would like to ask how you released the mirror from it's post on the glass. The early units had a torx screw (ok) but my C5 has no visible means of anything.
Gilly
Old 06-29-2013, 04:28 PM
jamieo
jamieo's Avatar
Mine is a 2000 model so it had the torx screw that secured it.Not sure how the later ones are mounted.
Old 06-29-2013, 05:49 PM
_zebra
_zebra's Avatar
yeah, mine occasionally does that, too (2000 FRC). if i use the dimmer switch or open the doors, it works fine & that's just what i've dealt with for over 2yrs now
Old 06-29-2013, 06:09 PM
Ohyoufan
Ohyoufan's Avatar
Mine did the same thing too, I just ripped all my LED's out and went back to factory lights cause I was tired of screwing with it. I'm contemplating going back though and trying something new with it.
To LED light issue
Quick Reply: LED light issue
