Day Time Running Lights
Old 06-29-2013, 06:35 PM
Super Gas
3rd Gear
Super Gas's Avatar
Default Day Time Running Lights
Have 2001 corvette.Is there any way to disable daytime running lights ?
Old 06-29-2013, 07:33 PM
Patches
Support Corvetteforum!
Patches's Avatar
Pull fuse #2 in the fuse box under the hood next to the battery. If you have your DIC set-up with "Approach Lights" on, it will not stop your fogs from coming on when you unlock the doors with the FOB but it will keep the reverse lights from coming on using the FOB. Other than that your reverse lights continue to operate normally. You will also have a fault code when you scroll through the DIC but it is harmless.
Quick Reply: Day Time Running Lights
