Need to Pin Crank if under 500 hp ?
Old 06-22-2013, 08:38 PM
magnoman
magnoman's Avatar
Default Need to Pin Crank if under 500 hp ?
Hada issue at track with my crank bolt coming loose think it was my bad not installing correct procedure .. going to get APR bolt and install was just wondering if there is a need to pin crank if not super charged and under 500 hp
Old 06-22-2013, 08:57 PM
martysauto
martysauto's Avatar
St. Jude Donor '14
The overwhelming response will be yes. You'll see. A loose balancer can damage the crank, the balancer and at the least throw your belts.
Old 06-22-2013, 08:59 PM
kmetros
kmetros's Avatar
Mine spun making 415 to the ground. I pinned it when I went back in. I wasn't going back a 3rd time! I wasn't sure if my problem was power or procedure so I was extra cautious the second time in.
Old 06-22-2013, 09:48 PM
dblerman
dblerman's Avatar
I would pin the crank even if our cars only had 200 HP. If you're in there it's just stupid to not pin it for cheap insurance.
Old 06-23-2013, 12:05 AM
NukeC5
NukeC5's Avatar
Pinned mine when the stock balancer failed. Went back together with an ATI damper and their pin kit. Car only has 305whp up to this point. But even so, it was nice to know it would never be a problem. After the H/C swap, I will be glad its already taken care of.
Old 06-23-2013, 12:16 AM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
VERY small price to pay while doing the same labor to remove/install a harmonic damper anyway regardless of HP.
No brainer.
Old 06-23-2013, 12:29 AM
lionelhutz
lionelhutz's Avatar
Pin it for sure. You've already spun it so the crank snout and balancer hole will both have some damage meaning the friction fit is looser now and it will be more likely to spin again.
To Need to Pin Crank if under 500 hp ?
Quick Reply: Need to Pin Crank if under 500 hp ?
