Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-21-2013, 01:11 AM   #1
NukeC5
CF Senior Member
NukeC5's Avatar
Default Finally time for the H/C swap
Dropping the car off tomorrow for the build. This one has been a long time coming. Its a shame I dont have time to do it myself as its my DD. This will be the first time I pay to do a cam swap.
Anyway, the car (99 A4) is pretty much fully built from the ground up and I saved the engine for last. Currently as the car sits, it made 305whp 293tq on a Dynolog dynomometer which has a 0% correction. The tunes were done with a FAST92/LS2 TB, and K&N intake with an axleback and x-pipe as the main bolt ons. Before the Fast, the car dynod at 325/325 with an LS6 intake on a dynojet. So I assume that car is in the 330's on a normal dyno.
Other than that, RPM stageII 3.42 diff, Yank billet 3200 stall, poly t-tube couplers, CCW drag pack w/ MT ET streets, Full Pfadt suspension: Feather light "drag specific" coilovers, heavy rate rear sway, poly control arm bushings, and solid engine/trans mounts. And interior stripped w/ a Sparco seat on race days.
All this has allowed me to make a consistent 1/8th mile @ 7.8 ET, 1.8 60' at 88mph.
Because figures are not usually given from this type of dyno, Im not sure what the reading will be after the tune. But I assume somewhere around 350-370 and a little over 400 on a normal dyno.
Any ideas on dyno numbers, and ET and top speed figures after the swap? Im expecting low 7's. Unsure about 60' and maybe 95mph.
Oh, the heads are fully P&P 243's w/ standard 64cc chambers (due to planned FI in the future). The cam is 222/228 on a 114. Everything else is the standard replacement stuff. Strong chain, high vol pump, It does have an ATI damper from when mine failed, lifters, etc.
Of course I will post results in a week when I get it back. But in the mean time I need to occupy myself with whatever I can and hopefully some good discussions on here.
NukeC5 is offline   Reply With Quote
Old 06-21-2013, 03:21 PM   #2
Toque
Toque's Avatar
Location: Wylie TX --> Less is More, except under the hood !
Good luck ! I bet its gonna be a beast ! ! !
Click the image to open in full size.
Toque is offline   Reply With Quote
Old 06-21-2013, 07:09 PM   #3
zeevette
CF Senior Member
zeevette's Avatar
I'd guess about 420 with the A4 and it's stall.
__________________
'02 black/black. LGM headers/cats/X. iForge "Aero" 18/19 combo. Koni FSDs. Trickflow/TEA heads,and HS rockers, MGW shifter.A&A Vortech V3si trim, and A&A COMP blower cam.RPS Twin Carbon Street. Tick master. Diff by RKT56. ECS brace. Pfadt diff brace. Somebody stop me...
I should be careful what I ask for....
zeevette is offline   Reply With Quote
Old 06-21-2013, 07:15 PM   #4
Rx7Rob
CF Senior Member
Rx7Rob's Avatar
Damn, its about time!
You're gonna love it!!
Rx7Rob is offline   Reply With Quote
Old 06-21-2013, 08:16 PM   #5
tiojames
CF Senior Member
Support Corvetteforum!
tiojames's Avatar
Send a message via MSN to tiojames
Before the blower install the vert put down 430RWHP with AFRs and a Comp 228/232, so you should be over 400 easy.
__________________
04 a4 Lemans vert-582 RWHP/500 ft. lbs.,228/232,205s,A&A Vortech kit,3500 Yank,3:42s,B&M cooler, wire insulators,long tubes w/jet hot coating, SS Works 3" X pipe and RT 3" hi-flo cats,170 stat,hood seal, catch can.,Z06 sway bars,DRM coilovers,tunnel plate,lowered,VIS carbon fiber extractor hood,ACI spoiler,blackouts,ss screens,ss letters,intake area screen,insulation kit, vert partition. C6 Z06 brakes,SS lines,DRM two piece rotors,front ducts,C6 Z06 rims, 9.5x18w2.85/30x18s,12x18w3.35/30x18s.
tiojames is offline   Reply With Quote
Old 06-21-2013, 08:52 PM   #6
NukeC5
CF Senior Member
NukeC5's Avatar
Spaceballs!
Quote:
I am thinking that the gears and the stall will milk the power down to the low 400 range. I may take it a shop with a dynojet too just to see where it stands with what most guys get tuned on. If its at or above 400, I'll be very happy.
I think it will be satisfying.. for now
Quote:
I agree. Not expecting much over 400 if at all. Hoping for the most of course though!
Old 06-21-2013, 08:54 PM   #7
NukeC5
CF Senior Member
NukeC5's Avatar
I must say, Im much more interested in the ET decrease rather than dyno numbers. But who doesn't like sexy dyno numbers right?
Old 06-22-2013, 10:31 AM   #8
RonSSNova
CF Senior Member
RonSSNova's Avatar
Good luck!
The ET/MPH will tell the story...if it still hooks up!
Ron
__________________
2000 MY C5 A4 (10.99 @ 123.7)
AFR 205's, Pat G 226/230, FAST 102/90, XS Power, Performabuilt, Yank SS3600, 3.42
69 Nova Alum 5.3 S476 Turbo on E85 (Tuning underway)
I'll be back for you Jack and I'll let the machine speak!
RonSSNova is offline   Reply With Quote
Reload this Page Finally time for the H/C swap
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
