Need some help with cam choice need to pass ca smog sniffer
So I'm look to buy this cam for my 00 c5 it is 224/230 580/580 lsa 15 will this cam pass ca smog if not what will and this is the rest off my setup
799 heads
BBK throttle body and intake manifold
BBk shorty header
Lg high flow cats with Magnaflow H pipe ,borla x pipe,and with a Granatelli axle back
tuning software undecided looking for recommendations
799 heads
BBk shorty header
Most Ca guys keep the duration in the 218-222 range and the LS @
116-117 but if you already have the cam I'd strongly suggest milling
those 799s about .035" AND using Cometic .040" or .045" head
gaskets to jack your compression up to 11.1-11.3 range and then a
SPOT-ON tune will get you there but any short cuts will fail. GL2YA
Lingenfelter makes a cam just for you! It's called the GT2-3 cam. Sits on a 118.5 LSA and the duration is in the range mentioned above. They claim a 20-30 horsepower increase depending on which cam your replacing with it (ls1 vs ls6 cam). I don't live in an emission state but this is probably the cam I'll be going with since it's real smooth and doesn't kill drivability.
http://www.lingenfelter.com/mm5/merc...1#.UcPL4hYwLww
799 heads
BBk shorty header
799 heads
BBk shorty header
That cam should pass CA smog - it has 3 degrees negative overlap. Cams with 0 and negative overlap will pass CA smog with a good tune. I passed with a 228/232 115LSA cam
What other mods did you have and what was the lift on your cam and what kind of power did you get and what shop tuned it thanks
Screw those small cams. Im a cali emissions choked owner too. I went with a 222/228 114lsa cam. Even a 224/228 has been shown to pass here a lot. But to be sure, I knocked the intake down a coupe degrees. I researched this for over a year before doing it. My tuner knows it will pass as well.
This is more like a 35-40hp cam.
Rick@Synergy did the tune
Ok cool thanks what size injector and duty cycle where you running oh and which push rods as well try to figure out what I'm going to need.
42lb injectors...duty cycle was very low/safe. I don't recall the pushrod length, the intaller had to measure to get the correct length
