Converting to regular tires
Is there any special procedures to convert my car from run flat to regular tires. Also, is there any advantages to that besides a lot more selections of tires?
advantages are weight reduction, wider variety of tires, and better performance tires, and much cheaper tires.
stock size are 245/45 17 and 275/40 18. When ditching the run-flats, i went with Nitto NTO5's in 255/40 17 and 285/35 18. Those are basically one size larger all around and fit perfect.
If you are going to transition to nonrunflat tires it would be prudent to purchase a tire repair kit and tire inflator.
It is important to maintain the stagger from front to rear or issues may arise with active handling.
Stock Sizing
Front wheels are 17" x 8.5" with +58mm offset and backspacing is 7". Total wheel width is 9.5".
Rear wheels are 18" x 9.5" with +65mm offset with and backspacing is 7.5". Total wheel width is 10.5".
245/ 45 -17 25.7" diameter *4.3" sidewall (Front-stock size)
275 /40 -18 26.7"diameter * 4.3" sidewall (Rear-stock size)
Stagger 1"
295/ 35 -17 26.1" *diameter *4.0" sidewall
255 /40-18 25.0"*diameter *4.1" *sidewall
Stagger 1.1"
255/45-17 26.1" *diameter *4.5" sidewall
285/40-18 27.0" *diameter *4.5" sidewall
Stagger .9"
255/40-17 25.0"*diameter *4.0" sidewall
285/35-18 25.9"*diameter * 3.9" sidewall
Stagger .9"
Little lower profile for looks and a touch wider.
But realize, not all brands have the same tread width...... e.g., a Bridgestone PP or a Kuhmo MX have significantly wider tread than, say, a Goodyear D3.
go to the tire rack and check out the specs.
I would not go much wider than a 285 on the rear tire, pushing the stock rim width size a little. Also watch the sidewall or profile height. You may not like too low or too tall of a profile or a different profile size from front to rear.
Here is a handy tire size calculator I think I picked up on Toque's website. The calculator will also give you the speedometer calibration of change if you decide it is worth having a tuner change the setting for you.
http://www.rimsntires.com/specs.jsp
Personally I went with Nitto Invo in stock sizing. Good Luck!
Stock Sizing
Stagger 1"
Stagger 1.1"
Stagger .9"
Stagger .9"
There are so many good tires out there...I went with the Hankook's because of Forum recommendations, prior history with Hankooks on another car, and price.
Enjoy your new ride.
Gunny John
PS. I have a set of almost new Goodyear runcraps for sale.
I went with kumho tires. The runflats were getting really noisy, and when I went around corners, the car would slide because the rubber was getting hard.
With the new tires, the only noise I hear is when I am stopping, just almost stopped, the road noise is apparent.
Otherwise, they are pretty quiet. I went with the original sizes. In fact, I liked them so much, I put C5 wheels and these tires on my C4.
<----------------------nice upgrade.
I did the same a couple of months ago. I kept every thing matched with the stock sizes, though. I put on a staggered set of Hankook V-12's and couldn't be happier; great ride, better traction, and sweet goodness, a much quieter ride. AND, at half the price.
Gunny John
Gunny John
I don't know where you got your figures from, but both your front and rear tires are smaller in diameter than stock.
Call me old-fashioned, but when most people want to go with larger tires, they want to fill out the wheel wells more (increasing diameter). A side benefit is that they usually get wider as a result. 99.9% of the views of your car is from the side. No one will notice a 2/5" increase in width, but they will notice a sizable decrease in diameter.
Nuke, can you show us a side shot of your car? I'm curious as to how much of a difference your tire setup makes.
You can't do that via the C5's options, but I've heard that you can with a tuner. You should ask this question as a new thread and you'll get more knowledgeable responses. This question can easily be overlooked by those who know, if they don't read this unrelated thread.
Hankook V12 EVO Review
I bought these tires in Feb. 2010. It's now June of 2013. I have nearly 22,000 miles on them. They are nearly down to the wear indicators with 3/32" left on all four tires. I'm a cautious driver at 59 years old and don't do burnouts or aggresive turns. The tires seem to perform well in all conditions except snow. I'm somewhat disappointed in the mileage but they are a performance tire. I bought them from PeP Boys mounted, balanced and alignment for $900. I received a $200rebate on their Buy 3 Get One Free program. I think I got about the best any one can expect from these tires. The price was right at the time I bought them. I'd buy them again. I went with the stock tire size 17" front, 18" rears.
