Difference between FAST 90mm intake and 92mm Help
Alright guys I just pulled off my intake and see that the bottom section is blown right out of the back... after calling fast and what not they told me the 90's are completely discontinued and I can no longer buy a bottom mounting section. Anyway I asked them if the 92mm bottom piece will work and he said no every intake is unique. But when searching and reading on here I see that people have used 90's tops on 78 bottoms... so anyway does anyone know if I can put my 90 top and mid section onto a 92mm bottom plate?
As far as the 78's and 90's go, those two are 100% interchangeable, the ONLY difference in a 78 and 90 is the snout size (top shell). The 92 is not interchangeable with any other FAST from what I've gathered. Sorry man.
