Normal idle RPM?
Old 05-16-2013, 09:03 AM
JBVETT
JBVETT's Avatar
Default Normal idle RPM?
Yesterday I noticed I had a unusually high RPM at idle. ( 950- 1000) So I took off airbridge, MAF, and connectors. Cleaned the MAF, then re-connected everything. Now I am down to around 725-750 RPM at idle with the A/C off. No codes are showing. I suspect that I had an air leak in addition to the dirty MAF. So my question is - Is 750 RPM idle speed normal for my C5? Thanks for a response.
99 Vert, 6 spd manual, Magnaflow axle back
Old 05-16-2013, 09:45 AM
3boystoys
3boystoys's Avatar
Sounds about right for automatics.
Old 05-16-2013, 10:07 AM
Zmeister
Zmeister's Avatar
For what it's worth my '04 Z seems to always be rock steady at 800 RPM.
Old 05-16-2013, 10:09 AM
chaase
chaase's Avatar
St. Jude Donor '12
725-750 is about right for 6spd. An A4 in gear will idle a little bit lower but I think you found the problem.
To Normal idle RPM?
Quick Reply: Normal idle RPM?
