Can't Reprogram Tire Sensors
I used OEM sensors. After changing everything out, I didn't want to cheap out and have another issue with after market sensors. BTW, if you have a convertible the receiver is easy to find and replace. The wiring colors are exactly the same from old to newer receivers so it's just a splice job. One tip if you go that way is to get the newer plug from the donor car for splicing in the wires to the receiver and you'll be done in 30 minutes... GOOD LUCK!
