Noise: rear end.C5
Old 05-07-2013, 05:41 AM
20fixed00roof
20fixed00roof's Avatar
Default Noise: rear end.C5
After a dyno tune a clunking sound became noticeable and is now not annoyance but a concern as the car is scheduled for a track day Sat. My C4 has clinking sounds and the axle u joints were replaced to resolve that issue. The C5 sounds a bit more chunkier than the C4 clinking. Seems the sounds are reduced under slight acceleration. Any of you drivers or technicians have any thoughts. Thanks.
Old 05-07-2013, 10:41 AM
SaberD
SaberD's Avatar
could be a ton of things. check all the bolts in the rear suspension and brakes for tightness.
Old 05-07-2013, 11:33 PM
MNCrystalRed2011
MNCrystalRed2011's Avatar
Check the spindle nuts on the rear wheels. They are known to come loose once in awhile. I've had to tighten mine a couple times.
Old 05-08-2013, 02:12 AM
striper
striper's Avatar
Loosen rear spindle nuts, popaxle ends in, lube axle splines and retighten nuts to spec. Fixed noise on mine.
To Noise: rear end.C5
Quick Reply: Noise: rear end.C5
