Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-27-2013, 04:35 AM   #1
Cliff8928
CF Senior Member
Cliff8928's Avatar
Cliff8928
Default Pass side output shaft seal came out!
So I was installing my LG Big 3 exhaust last week and I noticed some leakage around the passenger side output shaft. Upon further inspection, i saw the seal was actually out of the side cover almost touching the CV Joint. I grabbed a screwdriver out of the tool box, seeing if it would go back in easily, and it did with no effort. It's not being held in what so ever.
Click the image to open in full size.
Has anyone ever had this happen before? Is there anything that could've caused this (clogged vent, etc...) I just repaired the other side per the TSB instructions last year.
I'm probably going to head to the dealer in the morning and pick up a new seal. I got some Loctite 680 from a friend that I will use to install it, incase the cover is worn from the seal spinning in the bore.
Man, I hate gear lube.
Cliff8928 is offline   Reply With Quote
Old 04-27-2013, 02:09 PM   #2
corvettebob1
CF Senior Member
corvettebob1's Avatar
Yes a clogged vent will push out the axle seal, now what your most likely going to need is a new cover for that side.
When the seal gets pushed out it will spin in the cover bore and it doesn't take long for the steel seal to wipe out the aluminum covers bore.
corvettebob1 is offline   Reply With Quote
Old 04-28-2013, 02:47 AM   #3
Cliff8928
CF Senior Member
Cliff8928's Avatar
Cliff8928
I do remember checking that vent when I had the other side open last year... Oh well.
I picked up the new seal from the local dealer (in stock!), and installed it tonight. It didn't fit much tighter than the one that came out. The only difference is that I did use the Loctite 680 Retaining Compound when installing it. I figured I didn't have anything to lose if I'll have to replace the cover anyways. I'll just keep an eye on it when I drive it this week. (only 20 miles each way for work, minimal traffic)
On replacing the cover, is it that difficult? I was reading the service manual on it and it mentioned obtaining the correct shims for the bearing race for the carrier due to side cover bore differences.
Has anyone done this? I know my way with micrometers, calipers, etc. But does it require any specialized tools where this should be left to the pros?
Old 04-28-2013, 10:27 AM   #4
Mike94ZLT1
CF Senior Member
Mike94ZLT1's Avatar
I blew up a rear end this very way. I pushed a seal, it spun in the bore, and enlarged the hole. I got a new side cover, transferred the shims from my old cover, and put the new one on and made sure to torque it properly. Worked great for a day or two, but the first time I got on it... BOOM!
__________________
Just another stroked, err... I mean stock C5... That's just an exhaust leak and a bad miss...
"Those people are far more depraved & Satanic than I could ever be" - Marilyn Manson on the organizers of the Lilith Fair
Mike94ZLT1 is offline   Reply With Quote
Old 04-28-2013, 12:27 PM   #5
corvettebob1
CF Senior Member
Yes you will need the measure the new cover vs the old one the insure to maintain the same preload on the diff side bearings.
Old 04-28-2013, 01:50 PM   #6
Cliff8928
CF Senior Member
Cliff8928's Avatar
Cliff8928
Well, here's to hoping that Loctite works wonders, the maintenance guy at my work (former C5 owner) says it does!
If not, it may go into the shop for this one. I'll do almost anything myself, but I'm just not sure on this one. It could also be a good opportunity to have a Quaife installed.
Old 04-28-2013, 08:00 PM   #7
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Support Corvetteforum!
Bill Curlee's Avatar
If it were me and I had a loose seal,,,, I would JB Weld it in place. It will NOT come out once thats done!
That way you are not changing any rear end specs.
Even though you epoxy it in,, you can still get the seal out later on if necessary. It will just require a little more work.
Bill
Bill Curlee is offline   Reply With Quote
Old 04-28-2013, 11:13 PM   #8
Mike94ZLT1
CF Senior Member
Mike94ZLT1's Avatar
Bill
I really really really really really REALLY wish I had done this. That stupid seal cost me a new rear end and a transmission rebuilt, when it broke it tweaked my output shaft, AND bent my DTE brace! That was a built 3.90 3 rib rear with the 300M axle shafts. Anyways, clean it really well and put a new seal in there, and JB weld the snot out of it. Let it dry for a day or two and forget about it. Clean the vent on the top though!
Old 04-28-2013, 11:19 PM   #9
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you wind up epoxying it,, make sure that you get the seal metal outside clean and coating free and same for the diff housing to make sure that the epoxy adhears to the seal and the housing.
Thanks Mike.
Bill
Old 04-28-2013, 11:57 PM   #10
RonSSNova
CF Senior Member
RonSSNova's Avatar
I bet the loctite will work very well, as long as you got the seal bore totally oil free and dry.
Ron
__________________
2000 MY C5 A4 (10.99 @ 123.7)
AFR 205's, Pat G 226/230, FAST 102/90, XS Power, Performabuilt, Yank SS3600, 3.42
69 Nova Alum 5.3 S476 Turbo on E85 (Tuning underway 9.96 @ 143.26 so far)
I'll be back for you Jack and I'll let the machine speak!
RonSSNova is offline   Reply With Quote
Old 04-29-2013, 12:15 AM   #11
Cliff8928
CF Senior Member
Cliff8928's Avatar
Cliff8928
I cleaned it out with some Xylene and let it dry for a bit, same with the new seal. After sitting about 18 hours I tried to rotate the seal in the bore with a screwdriver in the notch and it wouldn't budge. Maybe I'll get lucky on this one. I've got some fresh Mobil1 gear oil to go in tomorrow and I'll be driving on Tuesday!
I appreciate everyone's assistance who chimed in on this!
Reload this Page Pass side output shaft seal came out!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Output Shaft Install - Left and Right Its_Go_Time C5 Tech 98 04-30-2014 04:59 PM
Leaky butt question Supercharged111 C5 Tech 1 05-13-2013 06:43 PM
Replaceing Caliper Seals l98tpi C4 Tech/Performance 8 03-16-2013 05:49 PM
Replacing LH output shaft, what else I need? srooper1980 C5 Tech 5 02-22-2013 08:43 PM
4 Speed - Shifter Shaft Seals goliath1 C3 Tech/Performance 0 07-28-2012 02:01 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
