2001+ Performance Figures
So i want to buy a used sports car, and I've decided on the C5 Vette due to the light weight, great handling and straightline power. I want to get the base model because it's cheaper then the C5Z, and i prefer the hatch look to the FRC look. Not to mention the Targa Tops will be a nice touch. Now i know the base coupe with the LS1 was rated at 345 Hp and 350 Tq and ran 0-60 in 4.7 and the 1/4 in 13.2 i believe. But i know from 2001 and up Chevy upped the LS1 to 350 hp and 375 tq for the manuel. Seeing as how i prefer manuel cars, i was wondering what kind of performance increase will i see with that extra 25 torque?
Overview of the 2001 Corvette
DETROIT -- The Chevrolet Corvette has been America's favorite sports car for 47 years, with more than one million sales and counting. During that time the Corvette has continually evolved and improved, always with an eye toward delivering a maximum amount of driving pleasure to those valuing high performance. For 2001, Corvette takes high performances and refinement to another level. "Corvette for 2001 offers more in several dimensions ... more performance, more agility and more refinements," said Dave Hill, Corvette chief engineer. "Corvette owners will be surprised and delighted at the result. We've expanded the envelope in every direction, especially with the new Z06."
NEW FOR 2001
For 2001, Corvette coupe and convertible models get a healthy injection of power, especially at lower speeds where it is most noticeable. They also get more agility, with the enhanced Second-Generation Active Handling system - a system that is now standard on all Corvettes.
In the area of refinement, Corvette buyers will appreciate better noise isolation, better idle quality and many other changes made to improve the overall ownership experience - and 2001 Corvettes even offer reduced maintenance costs and better fuel economy.
Perhaps the biggest part of the Corvette story for 2001 is the introduction of the new Corvette Z06, a production vehicle that's ready for the racetrack. Based on the former hardtop model - already the lightest, stiffest and quickest Corvette - it is a car aimed directly at diehard performance enthusiasts at the upper end of the high-performance market. It is very simply the quickest, best handling production Corvette ever, setting new standards in every part of the high-performance spectrum.
The Z06 designation was chosen to honor the efforts of Zora Arkus-Duntov, Corvette's first chief engineer, who in 1963 created the original Z06 package. Zora's special package was intended to make the then-new Sting Ray race-ready right out of the showroom, and today's Z06 has been developed with the same concept in mind.
MORE PERFORMANCE
Corvette coupe and convertible models for 2001 get more horsepower from the standard LS1 V8 - 350 hp (up from 345) - but the real story is a big boost in low-end torque.
Torque is what most customers really mean when they ask for "more power," and down low in the torque curve is where 2001 Corvette drivers will really feel the difference. Corvette engineers opened up the intake system, enabling the LS1 engine to pull in more air and the camshaft profile to be moderated in lift and overlap. The results are significant.
300 lb-ft is delivered at 1,000 rpm - 400 rpm earlier than before
320 lb-ft is delivered at 1,400 rpm - 800 rpm earlier than before
340 lb-ft is delivered at 2,500 rpm - an amazing 1,400 rpm earlier than before
Maximum torque of 360 lb-ft for automatics, 375 lb-ft for manuals, arrives at 4,400 rpm
NEW FOR 2001
MORE PERFORMANCE
Coupe Convertible Z06
General
Model 1YY07 1YY67 1YY37
Body Style 2-door
Hatchback Coupe 2-door
Convertible 2-door
Fixed-Roof Coupe
Passenger Capacity 2
EPA Vehicle Class Two-Seater
Primary Structure Unitized Steel
Body Material Fiberglass
Curb Weight, est. auto trans (kg/lbs.) (1) 1458/3214 1456/3210 1413/3115
Weight Distribution
(percent front/rear) (1) 51/49 51/49 53/47
Assembly Plant Bowling Green, Kentucky
Export Availability Europe, Middle East, Africa, Japan, Canada, Mexico Canada,
Mexico
(1) With automatic transmission on coup/convertible, manual on Z06
Restraints
Air Bags Std. Driver & Passenger
Safety Belts Std. Driver & Passenger
Suspension Package Availability
FE1 Suspension Standard N/A
F45 (w/Selective Real Time Dampening) Optional N/A
Z51 Performance Suspension Optional N/A
FE4 Suspension (Z06 only) N/A Standard
Suspension - Front
Type Short/Long arm (SLA) double wishbone
Features
Forged aluminum upper control arm
Cast aluminum upper control arm
Transverse-mounted composite leaf spring
Monotube shock absorbers (2)
Lubed-for-life ball joints
Individual wheel height adjusters
Stabilizer Bar diameter (mm/in) Std - 23.1 / .91
F45 - 23.1 / .91
Z51 - 28.6 / 1.13 FE4
30.0 / 1.18
Stabilizer Bar wall thickness (mm/in) Std - 3.81 / .15
F45 - 3.81 / .15
Z51 - 4.15 / .16 FE4
4.50 / .18
Shock Absorber dia. (mm/in) Std - 36.0 / 1.42
F45 - 54.0 / 2.13
Z51 - 45.0 / 1.42 FE4
45.0 / 1.77
(2) Includes Selective Real Time Damping control on F45 Suspension
Suspension - Rear
Type Short/long arm (SLA) double wishbone
Features
Cast aluminum upper & lower control arms
Monotube shock absorbers (3)
Stabilizer Bar diameter (mm/in) Std - 19.1 / .75
F45 - 19.1 / .75
Z51 - 21.7 / .85 FE4
23.6 / .93
(Hollow)
Stabilizer Bar wall thickness (mm/in) Std - 2.0 / .08
F45 - 2.0 / .08
Z51 - 3.0 / .12 FE4
3.5 / .14
F45 - 54.0 / 2.13
45.0 / 1.42
(3) Includes Selective Real Time Damping control on F45 Suspension
Stability Control System
Name Second-Generation Active Handing
Function Works with Corvette’s ABS and Traction Control systems to assist the driver in keeping the car stable and balanced in emergency or spirited driving conditions - on wet or dry surfaces.(4) Carefully calibrated to avoid unwanted intrusion into thedriving experience.
Special Componentry Brake pressure modulator, steering wheel angle sensor, lateral accelerometer, and unique core software algorithms.
2001 Improvements
Active Handling is now standard on all Corvette models
New lighter-weight Bosch 5.3 pressure modulator provides better overall response and improved pressure apply times in cold weather.
Electronic rear proportioning algorithm eliminates rear brake proportioning valve.
New algorithms for more precise, less intrusive control of sideslip angle rate, rear brake stability and wheelspin.
The unique-to-Corvette Competitive Mode may now be activated without bringing the car to a stop
(4) A Note of Caution: The overall effectiveness of the Corvette Active handling System is directly related to available tire traction and the aggressiveness of a given maneuver. Active Handling is designed to use existing traction to assist the driver - but it cannot overcome the laws of physics. Please drive responsibly.
Steering
Type Speed-Sensitive, Power-Assisted, Magnetic Variable Effort (MagnaSteer)
Ratio 16.1:1
Turns, lock-to-lock 2.66 2.46
Turning diameter,
curb-to-curb (m/ft) 12.0 / 39.4 12.9 / 42.3
Turning diameter,
wall-to-wall (m/ft) 12.3 / 40.3 13.2 / 43.3
Brakes
Type Four-Wheel Disc
Anti-lock system Four-Wheel (Bosch ABS V)
Rotor dia. X thickness,
front (mm/in) 302.3 x 1981.2 / 12.6 x 1.26
rear (mm/in) 302.3 x 1981.2 / 12.6 x 1.27
Swept area,
front,rear (sq cm/in) 1696 (F) 1018.0 (R) / 263 (F) 158 (R)
Wheels & Tires
Tires: Size Front - P245/45ZR-17 Front P265/40
ZR-17
Rear - P275/40ZR-18 Rear P295/35
ZR-18
Tires: Mfg./type Goodyear Eagle F1 GS
Extended-Mobility Goodyear Eagle
F1 SC
Wheels: Size (in) Front - 17 X 8.5 Front
17 X 9.5
Rear - 18 X 9.5 Rear
18 X 10.5
Wheels (Standard) Cast Aluminum
(Silver Sparkle) Forged Aluminum
(Lt. Gray)
Wheels (Optional) Forged Aluminum (polished) or Cast Magnesium N/A
Number of Studs 5 (front & rear) 5 (front & rear)
Spare None
Extended-Mobility Tires None
(GM Tire Inflator Kit included)
Engine
Order Code LS1 LS6
Type Overhead-Valve (OHV)
Pushrod V-8 Overhead-Valve (OHV)
Pushrod V8
Displacement (L /cc) 5.7L / 5665 cc 5.7 / 5665
Fuel Induction System Sequential Fuel Injector
Horsepower
(SAE net @ RPM) 350 @ 5,600 385 @ 6,000
Torque (lbs-ft @ RPM) 375 @ 4,400 (manual)
360 @ 4,000 (automatic) 385 @ 4,800 (manual)
Redline (RPM) 6,000 6,500
Fuel Shutoff RPM 6,200 6,600
Compression ratio 10.1:1 10.5:1
Firing Order 1-8-7-2-6-5-4-3
Block Cast Aluminum
Cylinder Heads Cast Aluminum
Intake Manifolds Composite
Exhaust Manifolds Cast Nodular Iron
Valves per Cylinder Heads 2
Hydraulic Roller Lifters Standard
Roller Rocker Arms Standard
Crankshaft Cast Iron w/Rolled Fillets
Camshaft Hollow Steel
Main Bearing Caps Powder Metal
Bore X Stroke (in/mm) 3.90 x 3.62 / 99.0 x 92.0
Cam Drive Chain
Recommended Fuel Premium Unleaded
Recommended Lubricant 5W/30 Mobil 1 Synthetic or equivalent
Recommended Oil Change Interval 15,000 miles or 1-year (under normal use)
Emissions Control
(NLEV Compliant) Catalytic Converter, 3-way Catalyst,
Air Injector Reaction (AIR),
Positive Crankcase Ventilation (PCV)
Additional Features Extended Life Spark Plugs,
Extended Life Coolant, Oil Level Sensor,
Oil Life Monitoring System
Engine Manufacturing St. Catherines, Ontario
Fuel Consumption (5)
Manual trans., EPA mileage (mpg city/hwy) 19 / 28 19 / 28 19 / 28
Automatic trans., EPA mileage (mpg city/hwy) 18 / 26 18 / 26 N/A
Max. cruising range, man/auto (mi) 482 / 450 482 / 450 482 / 450
Max. cruising range, man/auto (km) 775 / 724 775 / 724 N/A
(5) EPA labeling estimates apply to all Corvette models. Actual results may vary depending upon equipment level and driving habits.
Drivetrain
Type Front Engine, Rear Wheel Drive
Transmissions
Standard w/coupe & convertible Optional w/coupe & convertible Standard (w/Z06)
Hydra-Matic Borg-Warner (Tremec) Borg-Warner (Tremec)
Rear-Mounted Rear-Mounted Rear-Mounted
4-Speed Automatic 6-Speed Manual 6-Speed Manual
(4th Gear Overdrive) (5th - 6th Gear Overdrive) (5th - 6th Gear Overdrive)
(4L60-E) (T56) (T56)
Transmission Order Code M30 MM6 M12
Traction Control System Electronic; uses ABS brake system, electronic throttle control and spark retardation to control excessive wheelspin
Gear Ratios
Gear Ratios M30 4-Speed Automatic MM6 6-Speed Manual M12 6-Speed Manual
(Standard w/coupe & convertible) (Optional w/coupe & convertible) (Standard w/Z06)
1st 3.06:1 2.66:1 2.97:1
2nd 1.62:1 1.78:1 2.07:1
3rd 1.00:1 1.30:1 1.43:1
4th 0.07:1 1.00:1 1.00:1
5th - 0.74:1 0.84:1
6th - 0.50:1 0.56:1
Reverse 2.29:1 2.90:1 3.28:1
Axle Ratio 2.73:1 (std) / 3.15:1(perf)(6) 3.42:1 3.42:1
Final Drive Ratio 1.90 (std) / 2.19 (perf)(6) 1.71 1.92
(6) With optional Performance axle (available only with automatic)
Exterior Dimensions
Wheelbase (mm/in) 2655.5 / 104.5 2655.5 / 104.5 2655.5 / 104.5
Length, overall (mm/in) 4565.6 / 179.7 4565.5 / 179.7 4565.6 / 179.7
Height, overall (mm/in) 1211.5 / 47.7 1214.7 / 47.8 1211.5 / 47.7
Tread Width, front (mm/in) 1572.3 / 61.9 1572.3 / 61.9 1584.5 / 62.4
Tread Width rear (mm/in) 1574.5 / 62.0 1574.5 / 62.0 1589.5 / 62.6
Interior Dimensions
Head Room (mm/in) 963 / 37.9 960 / 37.8
Leg Room (mm/in) 1085 / 42.7 1085 / 42.7
Shoulder Room (mm/in) 1405 / 55.3 1405 / 55.3
Hip Room (mm/in) 1377 / 54.2 1377 / 54.2
Capacities
Passenger capacity 2 2 2
Interior Passenger Index (liters/cu ft) 1455 / 51.4 Data Not Available 1464 / 51.7
Cargo capacity (liters/cu.ft.) 702 / 24.8 394 / 13.9(7) 377 / 13.3
Fuel tank (liters/gallons) 70.0 / 18.5
Engine oil w/filter (liters/quarts) 6.15 / 6.5
Engine coolant (liters/quarts) 10.9 / 11.5
(11.2 / 11.8 w/manual trans.)
Battery Type Absorbent Glass Mat (AGM)
Performance Data
Power-to-weight ratio,
auto. trans. (lbs:hp) (8) 9.18 8.09
Specific output (hp:liter) 61.8 68
Acceleration (9)
0-60 mph, man. trans. (sec) 4.5 (manual)
5.0 (auto) 4.0 (manual)
top speed (kph/mph) (10) 281.6 / 175 275.2 / 171
1/4 mile manual (sec./mph) 13.22 / 109 mph 12.6 / 114
Lateral acceleration (g) 0.93 1.03
General
Body Style 2-door
Convertible 2-door
Fixed-Roof Coupe
Weight Distribution
Mexico
Restraints
Suspension - Front
Features
F45 - 23.1 / .91
30.0 / 1.18
F45 - 3.81 / .15
4.50 / .18
F45 - 54.0 / 2.13
45.0 / 1.77
Suspension - Rear
Features
F45 - 19.1 / .75
23.6 / .93
(Hollow)
F45 - 2.0 / .08
Z51 - 3.0 / .12 FE4
3.5 / .14
F45 - 54.0 / 2.13
45.0 / 1.42
2001 Improvements
Steering
Ratio 16.1:1
Turning diameter,
Turning diameter,
Brakes
Swept area,
Wheels & Tires
ZR-17
ZR-18
F1 SC
17 X 9.5
18 X 10.5
(Lt. Gray)
Spare None
Engine
Order Code LS1 LS6
Pushrod V8
Horsepower
Block Cast Aluminum
Cam Drive Chain
Emissions Control
Drivetrain
Transmissions
Gear Ratios
5th - 0.74:1 0.84:1
6th - 0.50:1 0.56:1
Exterior Dimensions
Interior Dimensions
Capacities
Performance Data
Acceleration (9)
