Cam guru's only please
Old 04-23-2013, 10:03 PM
bracketshark
bracketshark's Avatar
Default Cam guru's only please
I'm fixing to do the head cam upgrade on my 99 FRC. I had a set of 243's CNC ported they look good, @ the same time I bought my new cam from the CNC guys (I'd rather not call their name). I was told I should have no problem getting to 425 RWHP with the upgrades. I'm not going to list them all but I'm sure you have a good idea what it takes to get there, and I have them. My car will never be raced, by me anyway, I want there to be no doubt when listening to it run that it is a "cammed" car. With that said here are the specs on the cam I bought: intake centerline 109.6, intake lift .605, duration @ .050 is 230.9, LSA 113.9.
I'll mention I've got long tubes, no cats, Z06 ti's and Tony Mamo ported fast 90 and TB. Well, what should I expect sound wise with this cam? Thanks guys.
Old 04-23-2013, 10:29 PM
FourG63 97GST
FourG63 97GST's Avatar
This is an interesting question. not sure how to vocally "gauge" a cam.
but i'll compare it to steak, This cam sounds Medium-well done
Old 04-23-2013, 11:13 PM
bracketshark
I wonder if that's good or bad, I prefer my steaks medium rare.
Old 04-24-2013, 12:14 AM
CactusCat
CactusCat's Avatar
Not sure if you're actually asking what it will sound like... but I think it'll sound a lot like this.
Blair's cam is a 230/236 .591/.601 with 114+4. The advance (+4) on the lobes help it idle a bit smoother and slightly better low range power (comes on quicker) but not quite as strong on the top end (although no slouch at all). Your's will sound close to this, but probably have a bit more lope but a bit quieter than Blair's GHL's.
Old 04-24-2013, 04:17 AM
vettenuts
vettenuts's Avatar
It will have some chop to the idle but won't sound like a real lumpy cam. If you run a lower idle it will be more of a "cam" sound if that is what you are seeking. If you were just after sound, the GM hotcam would have done the job and would be easy on the valve train.
Old 04-24-2013, 08:03 AM
bracketshark
http://www.youtube.com/watch?feature...&v=9apjKAl0BD4
That's about what I was looking for. Let me ask another question. I bought a new set of 1.7 Yella Terra roller rockers, The head/cam guy advised not to use them, he advised that he would spec a different cam if I insisted on using the RR's. I gave in and agreed to use the stock rockers with the modified bearings. I'm now thinking I want a Jessel system on there. Just my preference though. Do Roller tipped rockers really affect cam operation? I've built many SBC's been a serious 1/8th mile bracket racer, and never heard this comment from a cam company. Was it smoke or something to it?
Old 04-24-2013, 09:52 AM
FourG63 97GST
He advance against because of the 1.7 ratio, not the roller tip. If he's a perfectionist and already spec the cam, changing the ratio, changes everything. The geometry will be off.
Old 04-24-2013, 10:37 AM
bracketshark
Well isn't the stock ratio 1.7 or is it 1.75? Whatever, I had the stock ratio roller rockers he didn't want me to use. Does the roller tip change the aggressiveness of the lobe design?
Old 04-24-2013, 12:11 PM
vettenuts
vettenuts's Avatar
Stock ratio is 1.7. Advantage of the YT's is the stellar wipe you can with them if you take the time to set them up. Disadvantage is they are aluminum and there have been some breakage issues in the past. I am running the YT's and was very happy with the wipe pattern I got with them. The stock rockers will scrub a very wide pattern, especially with your lift.
Not sure I understand his concern with the YT's unless he has some really fast ramp rate on the cam. He should provide more details.
Old 04-24-2013, 02:09 PM
bracketshark
I asked the question why and it quickly became more complicated than I could keep up with. That is one reason I asked here, to be able to reread the answers given and try and understand. It seems everybody has different ideas concerning rocker geometry. Try reading this:
http://speedtalk.com/forum/viewtopic.php?t=8650
or from Jim Miller :
http://www.mid-lift.com/intro-mid-lift.htm
it makes since for a while then gets too complicated for me.
To Cam guru's only please
Quick Reply: Cam guru's only please
