Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-24-2013, 09:15 AM   #1
Triton170
CF Senior Member
Triton170's Avatar
Default Beep in dash
I have an annoying beep/buzz that sounds like the old fashion headlight warning buzzers. It comes from behind the dash in the radio/AC vent area. Beep lasts for about a second (sometimes longer) and occurs after the car has been running about 2 minutes. Typically one beep then nothing. It will not do it again until the car is turned off and restarted.
The buzzing went away for a short time but it is now back but with a twist. Today when I turned on the turn signals it beeped on and off in sync with the turn signals.
Car is a 2000 Coupe (A4, Z51) and has the original radio/CD player. It throws no codes and has no known electrical issues.
I did a search and found some talk of the hazard switch causing problems with the brake lights and turn signals but those work fine. Any thoughts?
Triton170 is offline   Reply With Quote
Reload this Page Beep in dash
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
