Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-18-2013, 02:57 AM   #1
c4vetteontop
CF Senior Member
c4vetteontop's Avatar
Send a message via MSN to c4vetteontop
Default What would you recommend i do with my 98 T56.
I have added some extra power to my 98 6 speed. I have added a supercharger and the car is now making around 500 hp. I had to replace the Clutch setup because the stock setup was just not holding.
I upgraded to a monster stage 2. I just started taking the car to the track. I have only put about 6 passes on the car. I have noticed that my Syncors are starting to go. At first it was only 3rd-4th. but now i am noticing that i am getting a grindding from 2nd-3rd and also 4th-5th.
What would you recommend that i do to fix my problem. Should i upgrade the t56 that i have or should i pick up a c5 z06 t56 and just install that? what would be the best thing to do for my corvette.. I do plan on keeping the car and might do some heads and cams down the road.
c4vetteontop is offline   Reply With Quote
Old 04-18-2013, 10:20 AM   #2
SaberD
CF Senior Member
SaberD's Avatar
Send a message via AIM to SaberD
well if you want to maintain stock reliability, i would get it rebuilt with tr6060 components. There are a few shops that do this. RPM transmissions, and Eastcoast Performance to name a couple.
The c6z06 comes with 505 hp, and it comes with a tr6060 for a reason. Upgrade the diff as well.
SaberD is offline   Reply With Quote
Old 04-18-2013, 05:04 PM   #3
3sACROWD
CF Senior Member
You will likely need to upgrade your transmission.
Just for kicks and giggles, try a shifter alignment to see if that isn't your current issue. With you jamming through the gears, maybe your shifter lost it's alignment.
3sACROWD is offline   Reply With Quote
Reload this Page What would you recommend i do with my 98 T56.
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
