HELP ASAP, I need part #'s for factory Flywheel, Clutch, Pressure Plate, Throwout Bearing.
Re: HELP ASAP, I need part #'s for factory Flywheel,
The LS1 clutches are sold as kits that contain the flywheel, pressure plate and disc. I suggest the 2002 ZO6 clutch kit. It's a direct bolt on and can handle much more power than the typical LS1 unit.
Part numbers:
2002 ZO6 Clutch Kit: 12570806
2002 Master Cylinder: 12564455
2002 Slave Cylinder: 12562767
The throwout bearing is attached to the end of the slave cylinder so no need to order one, in fact you can't since it's attached to the slave.
To get the cheapest prices email Chris Slack at Team Chevrolet, chriss@teamchev.com and tell him Levi Procter sent you and he'll hook you up.
Part numbers:
