WHERE DID parts go wrong???
Put wife's 98 on Dyno Saturday. Very disappointing numbers!!
These are the mods
Blackwing
VRAM over radiator
Non screen maff
Bbk throttle body
Brand new stock injectors off crate motor
Zo6 over axle
And a tune
315 rear
365 at the crank
Held good till 5800 dropping off at 6000
Top speed was 158
Thought the numbers would be better by around 30 horse to 40
I know with ls intake and 243 heads and headers and heads it would be up there, but for a baseline???
I drive it and doing 75 it's getting 27 mpg!!
It only starts to dump a bit more fuel at around 5200 rpm
Shouldn't it get richer around 36 or 4200??
Any comments or input would be great
These are the mods
Blackwing
VRAM over radiator
Non screen maff
Bbk throttle body
Zo6 over axle
And a tune
315 rear
365 at the crank
Top speed was 158
Ya thats strange. Auto right?
My 99 auto based at 320 with only a k&n and ls6 intake and a axleback exhaust. Are your spark plugs good? Wires? Running good fuel?
Before all the rear end work I was getting 31mpg at that speed..
1 Post
has it been tuned?
If not, you will need to disconnect the battery and drive it for a day or two for the PCM to relearn....everytime I added bolt ons without a tune it took a good 4-6 hours of driving in various conditions before I really felt a signifigant differance in power with the but-o-meter.
The only thing you added that would increase HP was the Blackwing. I would expect numbers ~10-15rwhp over baseline with those mods, so 365bhp would be about right.
None of those mods really do anything so that sounds about right for me. If you haven't done plugs and wires yet, that could be a good start. When I did fresh plugs, wires, and long tubes I felt a huge increase.
I go to a tuner who uses a "Dynolog" dynomometer and have dynoed the same setup on a dynojet too. On the Dynojet Im at 340whp, on the Dynolog I am at 310whp. This is an uncorrected dyno and IMO, the most accurate. Its a heart breaker dyno, but when you think about it, its the most realistic.
