No Fuel Pressure
No Fuel Pressure
I have a 2004 z06, with a novi supercharger. The car has been sitting for approximately four months. Last week I fully charged the battery. Yesterday, the car stated up immediately and I let it run for about 5 - 10 mins. Three hours later I started the car up again, but while pulling it into the garage it shut off, exactly the same as if I turned the car off.
Now it won't start at all. Fuel pressure gauge shows 0. I swapped the FP relay with the horn and still read 0. I hotwired the relay and got 12 volts with the key in the "on" position. I checked the ground in the driverside rear wheelwell and it looked fine. I don't hear the fuel pump turn on. Are there any connections I can check closer to the fuel pump to ensure it has power?
do you have an inline fuse? I had a similar issue and the fuse in the inline holder from the BAP "looked" fine but when I pulled it out it disinegrated...replaced the inline holder and has been good ever since
That's a great question Pewter. Forgive my ignorance but where is the fuse normally located for a BAP? Is it usually in the driver side rear wheel well?
well.........once you locate your BAP module it should be easy to trace the red power wire and look for an inline fuse link ..mine was mounted/tucked up near my battery...
Thanks for your help Pewter, much appreciated.
You were right! It has an MSD BAP next to the battery with an inline fuse in the battery compartment. Sure enough, the fuse is blown. I'll pick up a new fuse tomorrow and give it a shot. There may be an issue with the MSD BAP as I've been reading they've been known to have problems.
Finally got a chance to get back to the car. The MSD BAP was absolutely the source of the issue. We bypassed the unit and the car started right up with 60 lbs of pressure. Guess I'll have to spring for a Kenne Bell BAP. Anything else I should buy besides the BAP? Wiring is already in place for the MSD.
