Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-22-2013, 12:25 PM   #1
ibfuelish
Junior Member
Default Properly Torquing OEM harmonic Balancer Bolt
For those of you who went back together OEM on the Harmonic Balancer R&R, what combination of tools did you use to torque the bolt.
I have the balancer installed to correct depth. I have torqued the old bolt to 240 ft/lbs. I have removed the old bolt and reinstalled a new OEM bolt and have torqued it to 37 ft/lbs. this is all per the service manuals.
However, I'm unable to get the new bolt torqued to yield at 140 degrees. I have an angle meter and I'm to about 80 degrees, but can't get a stiff enough setup to get that last 60 degrees.
Thanks for the help,
Mike
(2002 Base, manual)
ibfuelish is offline   Reply With Quote
Old 02-22-2013, 04:22 PM   #2
ibfuelish
Junior Member
Disregard, I finally got it. I had a 1/2 inch breaker that was longer than my 3/4 inch breaker. The 1/2 inch was flexing too much. Used 3/4 inch plus the handle from my jack to turn it the extra 60 degrees.
I'm old and my shoulders can't handle that kind of torque.
Mike
Old 02-23-2013, 07:07 PM   #3
gonbad
CF Senior Member
gonbad's Avatar
Yeah that was a fun job. Brings back some sore muscle memories.
gonbad is offline   Reply With Quote
Reload this Page Properly Torquing OEM harmonic Balancer Bolt
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
