99 Headline noise when shut and pop up w parking lights on
Received 1,984 Likes
I've researched a lot of posts and am confused. On a 99 the headlights now pop up but do not turn on when the parking lights are turned on. Turn on the lights and all is well. Then when the lights are turned off both lights close but the left headlight makes a grinding sound and the manual **** spins about 5 or 10 seconds and then shuts off.
I first thought it was a gear issue but now wonder if it a stop or something in the electrical system. Any suggestions where to start? Thanks
I agree with cdk and Chicago that at least part of your problem definitely sounds like a stripped/broken gear in the headlight motor assembly. Replace it. It's not terribly difficult to do and MUCH cheaper than buying another unit.
Brass gears are well liked by many folks here, but the nylon gears can also do an excellent job and cost roughly half the price, as long as you do your part and lubricate the headlight door mechanism periodically as well. Convinced that my factory nylon gears would go out sooner rather than later, I bought a brass replacement gear several years ago as a preventive measure to have on hand just in case, and it is still in it's original package. I've got 174K miles on my factory '99 nylon gears (yes, I bought the car new so I know they are originals) and about once a year or so I use a small oiler (using regular motor oil) and lubricate all the pivot points. Wipe off any excess and you're good to go.
Btw, you have the "good" motors that were installed from '97 to '99. They are the easiest to repair. Three screws hold the side cover on and no gluing/clamps/epoxy like the later '00-'04 versions.
HTH
HTH
I'm experiencing this same exact problem except the manual turn screw for the left light appears to spin freely. Does this also indicate my gear is toast?
Also, any vendors that sell the brass one with install instructions?
Cruise-In IV Veteran
Daytona Jam 1 Veteran
I agree with what others are suggesting and switched to brass gears a while ago when my 1999 coupe began having grinding issues. I also had to replace the control module.
The OP also says something about the headlights popping up when turning the parking lights on.
I think that normal operation would have the lights turned on causing them to pop up and then when backing off to parking lights the lights stay up but the lamps go out.
It seems OP is having the lights pop up prematurely and this may be caused by a control module issue.
The book says disconnect and remove the entire headlight assembly, but someone with small hands can remove the motors and replace the gear without taking out the entire assembly.
Just disconnect the electric plug, manually raise the headlights, remove the shroud and headlight lid and you can access the motors. Note position of the linkage rod when removing motor and reinstall in same position.
Cruising
I do not understand the connection between worn gears and the doors opening when turning on parking lights. mine was making the gear noise when closing and the doors opened when turning on parking lights. replaced gear and now no noise and parking lights do not open the doors, where's the connection ?
http://forums.corvetteforum.com/foru...s-or-more.html
