Help: Seat back flop and seat bottom "shift" NOT rocking seat.
Received 2,263 Likes
C4 of Year Winner (performance mods) 2019
So about 9 months ago I picked up some used Caravaggio Sport Seats. Seats are much nicer than stock sport seats from a seat perspective, but I'm having a few issues. First off, the seats tracks were worn out when I bought them, so they have already had the "rocking seat" fix done to them, the two issues I have are something else.
Hey, I came across a post you made a while back on the forum about there being different solutions for seat issues:
1. The backs of the seats flop forward significantly more than my stock seats did. I've found posts stating that earlier year seats had a weaker spring than the later year (my stock were 03, I don't know what the Caravaggio are based off of), and I'm thinking this might be the issue for this. Is there any way to fix/improve? Can I change out the springs that hold the seat back or add stronger ones?
2. The seat base still seems to shift a little bit on hard braking or when I push the clutch in while stopped. I initially thought maybe the seat was coming loose from the track, but all the bolts look tight. Also, when I was looking under the seat, there seems to actually be some play in the seat track mechanism itself. It's irritating enough that I'm actually contemplating buying a brand new GM track for the driver's side, but am trying to confirm if this will fix the problem before spending a lot of money on it.
Any advice?
Any advice?
I suspect we may have the same problem. I traced mine down to end play in the transmission/ball screw assembly for the tilt portion of the seat. I've got some video and photos I'll post tomorrow.
I removed the seat and tracks, mounted them to a couple of 2x4s, c clamped the whole thing across the forks of a forklift and then elevated it about 6 feet in the air so I could stand under it and observe where the movement was actually coming from.
Unfortunately, it appears the only solution is a new track a$$embly.
As far as I can tell there are no serviceable items available to fix these issues. I purchased a new seat track assembly from GM to fix mine. I'm in the process of machining some new parts to repair my old one.
Video of the seat tilt mechanism on a memory seat.
http://s1325.beta.photobucket.com/us...936da.mp4.html
