Exhaust leak from X Pipe to Catback
Old 02-10-2013, 01:56 PM
jgump
jgump's Avatar
Default Exhaust leak from X Pipe to Catback
Any ideas on how to cure this? I have the same leak on both sides were the X pipe connects to the catback.
I'm thinking new gaskets and using copper sealant on each side. I also may belt sand both surfaces to try and make them flatter.
I installed XS Power headers to my Ti Catback two years ago and has been leaking from day one. I did use new GM gaskets. To me it locks like two surfaces on not flat, or maybe my catback is cocked.
Old 02-10-2013, 02:02 PM
RonSSNova
RonSSNova's Avatar
Looks like one or the other flanges is not flat. I had to sand my catback, they were warped. I also have the XSPower setup.
Permatex orange silicone or any high temp sealer will work. Those GM gaskets are expensive, you might be able to re-use yours.
Old 02-10-2013, 02:17 PM
jgump
jgump's Avatar
Good deal. I just wanted to confirm what I was thinking. The gaskets should be ok, maybe 2K mile on them.
Old 02-10-2013, 02:18 PM
jgump
jgump's Avatar
From looking at it without taking it apart it looks like the catback maybe warped.
Old 02-10-2013, 02:24 PM
printmanjackson
printmanjackson's Avatar
St. Jude Donor '06-'07-'08-'09
belt sander works great
Old 02-10-2013, 07:31 PM
Quicksilver Vert 01
Quicksilver Vert 01's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Use two OEM gaskets on each flange connection, and coat both sides of each gasket with copper sealant.
Your old gaskets will be fine to reuse, so you will only need two more new ones.
Old 02-10-2013, 08:46 PM
NukeC5
NukeC5's Avatar
I used copper gasket maker to fix the leaks from this area. Its holding up fine.
Old 02-10-2013, 10:24 PM
onlyavette
onlyavette's Avatar
This is what we did for a friend who kind of has an OCD issue with this problem.
First we flattened both flanges. We then cut two 1" long pieces of stainless pipe, split them length wise and ground the edge until they press fit into the axle back. We welded the split back together to make a ring that fit inside the axle back and mid pipe. We pushed half the length inside the axle back pipe and tact welded them in three places. You have to make sure they will fit inside both pipes. We had to do a little grinding and smoothing to make sure they fit into all four pipes by 1/2" when bolted together. We had new gaskets but did all of this because we wanted to be sure it never leaked again. That was about 4 years ago and about 4 tear downs ago and it has never leaked a drop.
It may be overkill to some but different situations have different requirements.
I just let mine leak because from what I can see it is just condensation that collects there overnight. I have had a good look at them with the engine running and couldn't detect any exhaust leaking out.
Old 02-10-2013, 10:43 PM
madmatt9471
Support Corvetteforum!
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
"IF" you belt sand make sure you be careful on the Titanium side and use plenty of good ventilation and mask for particulates!
Or use Copper Hi-Temp gasket sealer - that will work for sure!
Thanks,Matt
Old 02-10-2013, 11:05 PM
jgump
jgump's Avatar
Yes I get the condensation drip when the car sits at idle.
Old 02-11-2013, 04:28 AM
steven31371
steven31371's Avatar
Thanks,Matt
Thats what I used, coated both sides of the oem gasket with it, then bolted everything back up....no leaks.
I also bought the 3" sealer band clamps from pep boys, slathered them in that same High Temp Gasket maker, and got rid of those C clamps that came with the system for the slip fit mid-pipe connection
was leaking there before too, not now.
Old 02-11-2013, 07:19 AM
Cybermind
Cybermind's Avatar
I've done this numerous times. Using two gaskets usually solves this issue. This also depends on the gasket quality. Some gaskets are better than others.
Or, buy gaskets with the embossed raised copper bead. It increases sealing pressure on the inside diameter of the pipe. These are excellent for sealing imperfect surfaces. They cost a little more but are completely worth it.
PS: I wouldn't worry too much about condensation drips. This does not necessarily mean that you have a leak. But, black soot does which is the case with the OP.
To Exhaust leak from X Pipe to Catback
Quick Reply: Exhaust leak from X Pipe to Catback
