Who's That Knocking?
Getting knock on hard acceleration. I'm using 91 octane (no ethanol). I have 23,000 miles on original plugs and am wondering if I should try to change them or if I should have it tuned first. I'm thinking of just having the tune done. There aren't any performance shops around, so I'm talking about taking it to the dealership.
There are no current codes.
The PCM contains 2 spark tables. High and Low octane. When the pcm detects knock, it begins to transition to and use the low octane table. The low octane table has significantly reduced timing.
So, sounds like either the knock sensors aren't working, have been retuned (sensitivity changed) or someone made the low octane table the same as the high octane table.
Again, a case where datalogging with HPT or EFI live while driving would reveal what is going on. Certainly could read the current tune and see if it has been messed with.
Ron
Ron
Ron
Ron
Thanks!
Ron
Ok, roads were bare and dry today so I got out and did the knock tests using the Torque ap on my Android phone. I did the test twice, starting at 35mph and hitting full throttle. The test only takes about 2 seconds and the speeds listed below are in error, as I never exceeded about 60mph. How does the timing look?
Test One:
"1 knock event from 7 samples.
knock event 1:
RPM 3,766.75, speed 87.3
Timing 29, Correction -1"
Test Two:
"2 knock events from 11 samples.
knock event 1:
RPM 3,541, speed 81.9
Timing 30.5, Correction -0.5
knock event 2:
RPM 3626, speed 86.4
Timing 30, Correction -0.5"
Personally, when I actually hear the knock, it's when I'm accelerating on a freeway onramp without using a lot of throttle and the transmission just kicking down into 3rd. Situations like that.
I also have the following test results that are taken with the same Torque ap and the engine at idle. I don't have a clue what these mean:
Mode $06 report generated by Torque for Android
Vehicle VIN: 1G1YY22G845102035
Vehicle Manufacturer: Chevrolet
Vehicle Calibration ID: 12585950
12586112
1258
Unit and scaling information are not supplied with the data from the ECU for this type of vehicle. Consulting the manufacturers service book for this information is recommended.
Test report:
TID:$02 CID:$04
- Lean to Rich sensor threshold voltage(constant)
Test incomplete or dependant test failed
TID:$02 CID:$06
Min: 32,868
Test result value: 32,868
PASS
TID:$02 CID:$11
Min: 375
Test result value: 376
PASS
TID:$02 CID:$30
TID:$02 CID:$40
TID:$02 CID:$50
Min: 32,898
Test result value: 32,898
PASS
TID:$02 CID:$60
Max: 33,018
Test result value: 32,778
PASS
TID:$02 CID:$66
Max: 32,838
Test result value: 32,774
PASS
TID:$02 CID:$71
Max: 32,888
Test result value: 32,763
PASS
TID:$05 CID:$01
- Rich to Lean sensor switch time(calculated)
Max: 65,535
Test result value: 14,944
PASS
TID:$05 CID:$02
Max: 65,535
PASS
TID:$05 CID:$03
Max: 65,535
Test result value: 8,000
PASS
TID:$05 CID:$04
Max: 65,535
Test result value: 19,999
PASS
TID:$05 CID:$05
Max: 16,320
Test result value: 2,368
PASS
TID:$05 CID:$06
Max: 16,320
Test result value: 1,856
PASS
TID:$05 CID:$07
Min: 15
Test result value: 108
PASS
TID:$05 CID:$08
Min: 15
Test result value: 102
PASS
TID:$05 CID:$0a
Max: 1,450
Test result value: 104
PASS
TID:$05 CID:$0b
Min: 22,719
Test result value: 22,914
PASS
TID:$05 CID:$0d
Max: 32,888 Min: 32,568
Test result value: 32,776
PASS
TID:$05 CID:$41
Max: 65,535
PASS
TID:$05 CID:$42
Max: 65,535
PASS
TID:$05 CID:$43
Max: 65,535
PASS
TID:$05 CID:$44
Max: 65,535
PASS
TID:$05 CID:$45
Max: 16,320
Test result value: 2,688
PASS
TID:$05 CID:$46
Max: 16,320
PASS
TID:$05 CID:$47
Min: 15
Test result value: 105
PASS
TID:$05 CID:$48
Min: 15
Test result value: 106
PASS
TID:$05 CID:$4a
Max: 1,450
Test result value: 91
PASS
TID:$05 CID:$4b
Min: 22,719
Test result value: 22,775
PASS
TID:$05 CID:$4d
Test result value: 32,773
PASS
TID:$0a CID:$0a
- Sensor period(calculated)
Max: 168
PASS
TID:$0c CID:$60
- Misfire counts for last/current driving cycles(calculated)
Max: 33,069
Test result value: 17,780
PASS
TID:$0c CID:$70
Max: 33,069
Test result value: 17,778
PASS
TID:$02 CID:$04
TID:$02 CID:$06
Min: 32,868
PASS
TID:$02 CID:$11
Min: 375
PASS
TID:$02 CID:$30
TID:$02 CID:$40
TID:$02 CID:$50
Min: 32,898
PASS
TID:$02 CID:$60
Max: 33,018
PASS
TID:$02 CID:$66
Max: 32,838
PASS
TID:$02 CID:$71
Max: 32,888
PASS
TID:$05 CID:$01
Max: 65,535
PASS
TID:$05 CID:$02
Max: 65,535
PASS
TID:$05 CID:$03
Max: 65,535
PASS
TID:$05 CID:$04
Max: 65,535
PASS
TID:$05 CID:$05
Max: 16,320
PASS
TID:$05 CID:$06
Max: 16,320
PASS
TID:$05 CID:$07
Min: 15
PASS
TID:$05 CID:$08
Min: 15
PASS
TID:$05 CID:$0a
Max: 1,450
PASS
TID:$05 CID:$0b
Min: 22,719
PASS
TID:$05 CID:$0d
PASS
TID:$05 CID:$41
Max: 65,535
PASS
TID:$05 CID:$42
Max: 65,535
PASS
TID:$05 CID:$43
Max: 65,535
PASS
TID:$05 CID:$44
Max: 65,535
PASS
TID:$05 CID:$45
Max: 16,320
PASS
TID:$05 CID:$46
Max: 16,320
PASS
TID:$05 CID:$47
Min: 15
PASS
TID:$05 CID:$48
Min: 15
PASS
TID:$05 CID:$4a
Max: 1,450
PASS
TID:$05 CID:$4b
Min: 22,719
PASS
TID:$05 CID:$4d
PASS
TID:$0a CID:$0a
Max: 168
PASS
TID:$0c CID:$60
Max: 33,069
PASS
TID:$0c CID:$70
Max: 33,069
PASS
TID:$02 CID:$04
TID:$02 CID:$06
Min: 32,868
PASS
TID:$02 CID:$11
Min: 375
PASS
TID:$02 CID:$30
TID:$02 CID:$40
TID:$02 CID:$50
Min: 32,898
PASS
TID:$02 CID:$60
Max: 33,018
PASS
TID:$02 CID:$66
Max: 32,838
PASS
TID:$02 CID:$71
Max: 32,888
PASS
TID:$05 CID:$01
Max: 65,535
PASS
TID:$05 CID:$02
Max: 65,535
PASS
TID:$05 CID:$03
Max: 65,535
PASS
TID:$05 CID:$04
Max: 65,535
PASS
TID:$05 CID:$05
Max: 16,320
PASS
TID:$05 CID:$06
Max: 16,320
PASS
TID:$05 CID:$07
Min: 15
PASS
TID:$05 CID:$08
Min: 15
PASS
TID:$05 CID:$0a
Max: 1,450
PASS
TID:$05 CID:$0b
Min: 22,719
PASS
TID:$05 CID:$0d
PASS
TID:$05 CID:$41
Max: 65,535
PASS
TID:$05 CID:$42
Max: 65,535
PASS
TID:$05 CID:$43
Max: 65,535
PASS
TID:$05 CID:$44
Max: 65,535
PASS
TID:$05 CID:$45
Max: 16,320
PASS
TID:$05 CID:$46
Max: 16,320
PASS
TID:$05 CID:$47
Min: 15
PASS
TID:$05 CID:$48
Min: 15
PASS
TID:$05 CID:$4a
Max: 1,450
PASS
TID:$05 CID:$4b
Min: 22,719
PASS
TID:$05 CID:$4d
PASS
End of report.
Test One:
knock event 1:
Test Two:
knock event 1:
knock event 2:
12586112
1258
Test report:
TID:$02 CID:$04
TID:$02 CID:$06
Min: 32,868
PASS
TID:$02 CID:$11
Min: 375
PASS
TID:$02 CID:$30
TID:$02 CID:$40
TID:$02 CID:$50
Min: 32,898
PASS
TID:$02 CID:$60
Max: 33,018
PASS
TID:$02 CID:$66
Max: 32,838
PASS
TID:$02 CID:$71
Max: 32,888
PASS
TID:$05 CID:$01
Max: 65,535
PASS
TID:$05 CID:$02
Max: 65,535
PASS
TID:$05 CID:$03
Max: 65,535
PASS
TID:$05 CID:$04
Max: 65,535
PASS
TID:$05 CID:$05
Max: 16,320
PASS
TID:$05 CID:$06
Max: 16,320
PASS
TID:$05 CID:$07
Min: 15
PASS
TID:$05 CID:$08
Min: 15
PASS
TID:$05 CID:$0a
Max: 1,450
PASS
TID:$05 CID:$0b
Min: 22,719
PASS
TID:$05 CID:$0d
PASS
TID:$05 CID:$41
Max: 65,535
PASS
TID:$05 CID:$42
Max: 65,535
PASS
TID:$05 CID:$43
Max: 65,535
PASS
TID:$05 CID:$44
Max: 65,535
PASS
TID:$05 CID:$45
Max: 16,320
PASS
TID:$05 CID:$46
Max: 16,320
PASS
TID:$05 CID:$47
Min: 15
PASS
TID:$05 CID:$48
Min: 15
PASS
TID:$05 CID:$4a
Max: 1,450
PASS
TID:$05 CID:$4b
Min: 22,719
PASS
TID:$05 CID:$4d
PASS
TID:$0a CID:$0a
Max: 168
PASS
TID:$0c CID:$60
Max: 33,069
PASS
TID:$0c CID:$70
Max: 33,069
PASS
TID:$02 CID:$04
TID:$02 CID:$06
Min: 32,868
PASS
TID:$02 CID:$11
Min: 375
PASS
TID:$02 CID:$30
TID:$02 CID:$40
TID:$02 CID:$50
Min: 32,898
PASS
TID:$02 CID:$60
Max: 33,018
PASS
TID:$02 CID:$66
Max: 32,838
PASS
TID:$02 CID:$71
Max: 32,888
PASS
TID:$05 CID:$01
Max: 65,535
PASS
TID:$05 CID:$02
Max: 65,535
PASS
TID:$05 CID:$03
Max: 65,535
PASS
TID:$05 CID:$04
Max: 65,535
PASS
TID:$05 CID:$05
Max: 16,320
PASS
TID:$05 CID:$06
Max: 16,320
PASS
TID:$05 CID:$07
Min: 15
PASS
TID:$05 CID:$08
Min: 15
PASS
TID:$05 CID:$0a
Max: 1,450
PASS
TID:$05 CID:$0b
Min: 22,719
PASS
TID:$05 CID:$0d
PASS
TID:$05 CID:$41
Max: 65,535
PASS
TID:$05 CID:$42
Max: 65,535
PASS
TID:$05 CID:$43
Max: 65,535
PASS
TID:$05 CID:$44
Max: 65,535
PASS
TID:$05 CID:$45
Max: 16,320
PASS
TID:$05 CID:$46
Max: 16,320
PASS
TID:$05 CID:$47
Min: 15
PASS
TID:$05 CID:$48
Min: 15
PASS
TID:$05 CID:$4a
Max: 1,450
PASS
TID:$05 CID:$4b
Min: 22,719
PASS
TID:$05 CID:$4d
PASS
TID:$0a CID:$0a
Max: 168
PASS
TID:$0c CID:$60
Max: 33,069
PASS
TID:$0c CID:$70
Max: 33,069
PASS
TID:$02 CID:$04
TID:$02 CID:$06
Min: 32,868
PASS
TID:$02 CID:$11
Min: 375
PASS
TID:$02 CID:$30
TID:$02 CID:$40
TID:$02 CID:$50
Min: 32,898
PASS
TID:$02 CID:$60
Max: 33,018
PASS
TID:$02 CID:$66
Max: 32,838
PASS
TID:$02 CID:$71
Max: 32,888
PASS
TID:$05 CID:$01
Max: 65,535
PASS
TID:$05 CID:$02
Max: 65,535
PASS
TID:$05 CID:$03
Max: 65,535
PASS
TID:$05 CID:$04
Max: 65,535
PASS
TID:$05 CID:$05
Max: 16,320
PASS
TID:$05 CID:$06
Max: 16,320
PASS
TID:$05 CID:$07
Min: 15
PASS
TID:$05 CID:$08
Min: 15
PASS
TID:$05 CID:$0a
Max: 1,450
PASS
TID:$05 CID:$0b
Min: 22,719
PASS
TID:$05 CID:$0d
PASS
TID:$05 CID:$41
Max: 65,535
PASS
TID:$05 CID:$42
Max: 65,535
PASS
TID:$05 CID:$43
Max: 65,535
PASS
TID:$05 CID:$44
Max: 65,535
PASS
TID:$05 CID:$45
Max: 16,320
PASS
TID:$05 CID:$46
Max: 16,320
PASS
TID:$05 CID:$47
Min: 15
PASS
TID:$05 CID:$48
Min: 15
PASS
TID:$05 CID:$4a
Max: 1,450
PASS
TID:$05 CID:$4b
Min: 22,719
PASS
TID:$05 CID:$4d
PASS
End of report.
