Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-22-2013, 11:30 PM   #1
bobsiller
Junior Member
Default $1000 for water pump and thermostat replacement
Is this a good price or totally outrageous for a c5? Seems the repair is simple but not sure for bay area California?
bobsiller is offline   Reply With Quote
Old 01-22-2013, 11:41 PM   #2
superjet701k
CF Senior Member
superjet701k's Avatar
superjet701k
Huge rip off
superjet701k is offline   Reply With Quote
Old 01-23-2013, 12:36 AM   #3
Lothar34
CF Senior Member
Lothar34's Avatar
Lothar34
Send a message via AIM to Lothar34 Send a message via Yahoo to Lothar34
Does that include parts? And a happy ending?
Lothar34 is offline   Reply With Quote
Old 01-23-2013, 12:46 AM   #4
C5Natie
CF Senior Member
C5Natie's Avatar
Whoa! A stock replacement pump is around $140 or so. Thermostat you can get for $30 and its only a total of 8 bolts between both parts. Oh and gaskets, another $5. I suggest look at some diy threads here and get your ratchet with a 10mm socket. Thats all youll need. Oh and some coolant. The whole job should be maybe $200. No way labor is $800 when you can do it in an hour.
C5Natie is offline   Reply With Quote
Old 01-23-2013, 01:51 AM   #5
bill mcdonald
CF Senior Member
This has to have been one of the easiest cars I have ever replaced a water pump on. 1000 bucks is a rip off.
bill mcdonald is offline   Reply With Quote
Old 01-23-2013, 05:51 AM   #6
PhysicsDude55
CF Senior Member
PhysicsDude55's Avatar
Wow, I paid less to have my water pump replaced on a previous car that was driven by the timing chain and took 5 hours to replace.
Definite rip-off.
PhysicsDude55 is offline   Reply With Quote
Old 01-23-2013, 07:33 AM   #7
runner140*
CF Senior Member
runner140*'s Avatar
Hope that included a great dinner and a happy ending.
runner140* is offline   Reply With Quote
Old 01-23-2013, 09:48 AM   #8
Lloyd Christmas
CF Senior Member
Lloyd Christmas's Avatar
To put it into perspective for you, a reputable speed shop quoted me $1,000 to R&R the engine in my 2004.
Lloyd Christmas is offline   Reply With Quote
Old 01-23-2013, 09:51 AM   #9
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5&C6 609-752-0321
We can powder coat the water pump any color you want and throw in a dyno tune afterwards and you would still have change.
DOUG @ ECS is offline   Reply With Quote
Old 01-23-2013, 09:54 AM   #10
bumble-z
CF Senior Member
Quote:
Plus it would be done right with no problems afterwards.
bumble-z is offline   Reply With Quote
Old 01-23-2013, 10:25 AM   #11
Patches
CF Senior Member
Support Corvetteforum!
Patches's Avatar
Simple fix for less than $200 if you do it in your garage. I've done this several times before and it's a 3/10 for even the occassional DIY'er - last time was over the Xmas holiday on the wife's C5.
Be prepared for a huge rush of coolant when you pop the old pump off, though - even after you drain the radiator, there will be a lot of coolant that drains from the block. Usually, the new gaskets (2) come with the new/rebuilt pump. Make sure they are in the box when you pick up the new pump. Also, make sure you get a new O-ring with the new Tstat and be careful that it seats properly. I use blue Loctite on the pump bolts.
Patches is offline   Reply With Quote
Old 01-23-2013, 11:38 AM   #12
K-Spaz
CF Senior Member
K-Spaz's Avatar
On my 98, it was quite a chore to remove all the paper gasket (which was more like ceramic by the time I did the job). You'll need a good razor scraper and plenty of blades. I think someone said on later models they don't have the gaskets, and that would be a huge improvement. But, even still, $150 in labor at $75/hour is too much. $175 in parts, and you're out the door.
K-Spaz is offline   Reply With Quote
Old 01-23-2013, 11:43 AM   #13
mchicia1
CF Senior Member
It is like an hour of labor.
Amazing.
mchicia1 is offline   Reply With Quote
Old 01-23-2013, 03:11 PM   #14
OneFast1
CF Senior Member
OneFast1's Avatar
Quote:
You may have a shop that is unfamiliar with Corvette and does not know the "going rate" or has not done enough water pump replacements to be familiar with the job. Or they are just takng you for a ride, either way I would not want this shop working on my car.
OneFast1 is offline   Reply With Quote
Old 01-23-2013, 03:19 PM   #15
C5Natie
CF Senior Member
C5Natie's Avatar
Use the aluminum gaskets with a o-ring.
Click the image to open in full size.
Old 01-23-2013, 05:19 PM   #16
Big_George_S
CF Senior Member
Big_George_S's Avatar
Default Rip off.
I just did mine and upgraded to an electric pump and I'm not the sharpest machanic in the box. If you are uncomfortable doing it yourself and don't belong to a corvette club with members that can help you I'd suggest you look ask around your area for a good independent shop that you can trust.
Good luck.
Big_George_S is offline   Reply With Quote
Old 01-23-2013, 06:11 PM   #17
John Shiels
CF Senior Member
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
When you go there hold on to your ankles. Ask him for a parts and labor break down. Then ask for shop manual hours. He can charge what ever he wants it's up to you to decide.
John Shiels is offline   Reply With Quote
Old 01-23-2013, 06:12 PM   #18
dannyman
CF Senior Member
dannyman's Avatar
Totally outrageous!
Due yourself a favour and find an honest shop. There's still some out there.
I'd be looking for some local forum members and find out who they trust and deal with, if you can't do these repairs yourself.
Yes, outrageous!!
Dan
dannyman is offline   Reply With Quote
Old 01-23-2013, 06:19 PM   #19
Evil-Twin
CF Senior Member
St. Jude Donor '03-'04
Evil-Twin's Avatar
if it takes an hour to swap out water pumps on a C5, it might be your first time doing it.. if a professional mechanic does it it should take 45 minutes.. shops around here are 100 an hour so this job labor cost should be 100 dollars. add two gallons of coolant and a new stat and the pump and its a 400 dollar job at best.,,do it your self and its under 300 dollars.
Evil-Twin is offline   Reply With Quote
Old 01-23-2013, 09:46 PM   #20
cruisemon
CF Senior Member
cruisemon's Avatar
Quote:
Better include a kiss and a cigarette.
Charlie
cruisemon is offline   Reply With Quote
Reload this Page $1000 for water pump and thermostat replacement
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
