Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-18-2013, 09:42 PM   #1
hiperf454
CF Senior Member
Support Corvetteforum!
Default Replaced trans and put linkage on unside down
I changed the clutch on my 03Z replaced the trans with an MN6 that was built. Rebuilt the torque tube with new couplings from RPM. New bearings. All new seals in the rear end. new Axles. I broke an ear off the shift linkage. I got another then disaster struck. I come down with the flu and was hospitalized. The car sit for a month. I believe I put the shift rod in upside dowh. I got an inspection camera today and tried to tell but I really could not tell. I went to the dealer and got a print off of the torque tube with the shift linkage going through. The only reason I even though of it was the shifter bolt brass piece was upside down. I guess I will drop the mid pipe and the center panel to look at it and if its not right tear it all apart. Does anyone have a picture of the torque tube going through the torque tube? I have a shop and have put a clutch in this before. However never changed the trans. Any help would be great. I love doing things twice.
hiperf454 is offline   Reply With Quote
Old 01-19-2013, 12:16 AM   #2
hiperf454
CF Senior Member
Guys,
I really need some help here. I just finish putting this together and I cant find a picture of the shift linkage coming out of the torque tube. I still have pneumonia and I really dont want to take this all apart again. Should I just put the shifter in and try and run it through the gears?
Kelly
Old 01-20-2013, 10:45 PM   #3
hiperf454
CF Senior Member
Thanks for the help. I fixed it in under an hour with a tool I built.
Reload this Page Replaced trans and put linkage on unside down
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
