Don't wait till you scrape! Check this out!
Supporting Vendor
Had a customer tell me that Fangs are "preventive maintenance". Thats a good way to put it. He said it as in changing your oil before you spin a rod bearing.
To Protect your lower radiator support before its gets beat up and broken.
Matt
Matt
Supporting Vendor
We offer many more of the top name brand products then we have advertised on the forum and our website. Email or pm us with what your looking for and we will be glad to get back to you with quotes and do our best to save you $$$.
Thanks,
Matthew
Thanks,
Matthew
Bought 2 sets a few months back,
Just installed last weekend on 1998 and 2004
these look awesome, easy to install and I believe
should save your Skid Bar- Lower Radiator Support.
Thanks SacCityCorvette for a great product...
Supporting Vendor
Thank you gr8-78 and Outlawtorn for your business!
just installed set on my C5. I'll let everyone know how the hold up after 6 mos.
I immediately backed out of my garage and scrapped the fangs on the driveway, but left no marks.
Supporting Vendor
Hi 1998BlackPlasticToy,
We have had a few customers install theirs without jacking the Vette up. But I would recommend getting it high enough so you can get to the bolt easily. The Fangs are easy to install.
Christian
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Have had mine on for about a year (40K miles). Have a few "rub" marks but still look great. I am lowered on stock bolts too.
#35
I just ordered fangs
Glad I saw this thread, just sent my order in for a set of black C5 fangs..... I painted my scraped up skid bars but these fangs look like the perfect protection especially because I'm lowered and scrape a lot.
I'll post up my review once I get them and install them myself!
#36
Supporting Vendor
The C6 lower radiator support is aluminum so its especially fragile.
#38
St. Jude Donor '10
Went searching for another topic and found the fangs. Just ordered a pair for my 2004 C5. Cheap protection considering the alternative!
Bob
Bob
Hi Everyone!
C5/C6 Corvette owners know that the front skid plates are vulnerable to getting bumped and scraped. Fangs from SacCityCorvette provide the best possible protection available for your front skid Plates/Lower Radiator support on your C5/C6 Corvette. Made of a High Impact Superior Performance Plastic, the C5/C6 Fangs are extremely impact resistant and 6 times more abrasion resistant than steel and Installation only takes a few minutes. Being only 1/8" thick you will not even notice any clearance loss. There is NO drilling or modification required! Once the Fangs are installed you will have the best protection available. $49.99 is a very small price to pay for such good protection of such an expensive part of your Vette!
(Note: we still have the screw on C6 Fangs for those who prefer them. Check our website)
2)The superior performance plastic we use is 6 times more abrasion resistant than steel making them slide very smoothly over what ever they come into contact with.
3)They perform perfectly in hot or cold weather.
4) They distribute the load over the entire skid plate where it is the strongest and can evenly distributes the impact, not on one side or the other where the side load can bend skid plate.
5)There are no moving parts to wear out.
6)They only weigh 5oz for those that worry about weight.
7)There is no drilling or modification needed to install them
8)The Fangs give protection over the entire skid plate. So if you bump up on a parking block like we demonstrate in our video you are protected from the front to back and from the highest point of the skid plate to the lowest.
9)They look like something that came on your Vette from the factory.
Here is a video of the Fangs getting used!
http://www.saccitycorvette.com/See-t...n-Action-.html
Here is info for the C5 Fangs
http://www.saccitycorvette.com/Fangs.html
Info for the C6 Fangs (Note: we still have the Screw on C6 Fangs for those who prefer them. Check our website)
http://www.saccitycorvette.com/C6-Fangs.html
Some of the Benefits
1) They are only 1/8” thick so there is no noticeable ground clearance loss. That’s very important since there is not much clearance there to begin with!2)The superior performance plastic we use is 6 times more abrasion resistant than steel making them slide very smoothly over what ever they come into contact with.
#39
Supporting Vendor
Thank you Bob for your business, we really appreciate it!
Christian
Christian
