Oil Pressure Question
Vehicle: 99 C5 with 75k miles
oil and filter: Mobil 1
About 2k miles on this oil change
Idle oil pressure 38
Oil pressure at 2k RPM 63
This is about 15 psi higher than it has been for several thousand miles. What does this mean?
a. nothing to be concerned about
b. clogged oil filter
c. failing oil pressure sensor
d. the Mayan aliens are here.........
Your insight, pls
Your insight, pls
Have you allowed the oil to warm all the way up? Use the DIC to see when the oil reaches 200+ degrees and then check the pressures. The cooler the oil, the higher the pressure will be; and obviously the warmer it is, the lower the pressure will be.
I understand this characteristic of dino oil but I thought that Mobil 1 has constant viscosity when cool or hot....
No. Oil is oil synthetic or not. Thicker when cold thins when hot. Mine with synthetic 10W30 Idles cold at a little over 40psi. At operating temp about 30psi.
Received 1,762 Likes
Cold about 65 then warmed up goes to about 30 to 35. But I am also useing 20w 50 amsoil...Robert
Your insight, pls
Your insight, pls
Premium Supporting Vendor
Straight from Mobil 1's website, the Mobil 1 5w30 viscosity:
100F: 61.7 cSt
212F: 11.0 cSt
300F: 3.1 cSt
Note that a 30 grade oil is partially defined as having a viscosity of 9.30-12.49 at 212F.
Also note that I check the oil websites pretty often and I think that this is a bump in viscosity for the Mobil 1. My recollection is that it was closer to 10 cSt at 212F not to long ago. It's possible Mobil 1 raised their viscosity a little and you are noticing that.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
