Oil pressure gauge pinned, oil pressure sensor replacement problem
http://www.youtube.com/watch?v=5PvlDLcyXX8
Whatsup everyone...I watched this video and am trying to replace my oil pressure sensor sending unit, but am having some trouble. I got the clip that holds the sensor in place off the sending unit, I can see the sending unit on the back of the block, but I am having trouble getting the deep socket onto the unit. It looks like theres a thick hose that runs along the back of my engine block that connects to the driver side cylinder head, so I am guessing this is either an oil line or a coolant line. No where in this video does he mention anything about removal/disconnect, but I dont know if I'll have enough room to get the socket onto the sending unit if I don't disconnect this. Any ideas? I am trying to avoid having the pull the intake manifold off if possible. Thanks
FWIW, removing the intake manifold isn't as much work as a lot of people make it out to be. Probably would have been done faster in the long run if you had pulled the manifold to begin with haha
That's the hose. Does it just pull right out? What's it for? I could probably set it aside and re-connect once finished with the sending unit replacement. I toyed with the idea of the other method (cutting the plastic under the cover below the windshield wipers), but if possible, would like to avoid this.
It just pulls off at the ends but the problem is getting it out after it's disconnected. Beware that inside the rubber is very fragile and expensive plastic piping. I suppose it's fragile due to the high temperature and heat cycles of it's location.
Really, pulling off the manifold is very do-able. You'll be surprised at how simple it is compared to the old cast iron small blocks. Once the manifold is out of the way the sender is right in front of you.
I may give the video version another try, otherwise, I may just do the "cut" method and chop a hole in the plastic underneath the windshield wiper tray (this is covered once you re-assemble everything so you can't see the hole.) Plus I hear that this part is one of the more common failing parts on our cars; I don't want to have to pull the intake manifold if it ends up going bad again at some point.
Just curious why you are so adamant about not pulling the manifold.
Not doubting you, I took a look at a sticky on removing the intake manifold and it doesn't look like a big deal, just seems like a bit much for what (in another location on the car) would be a fast swap. The other thing is I been busy at a new job and have a DD to commute in (beater civic lol), so I'm just taking my sweet ol' time on this lol. I also got an A&A kit on my car and don't feel like doing much disassemble to fix this. Will most likely be doing the cut method.
Cruise-In VII Veteran
if you pull the intake, have a good shop vac ready; I haven't seen one yet without a handful of sand underneath it
cutting the cowl method works, but I just can't do it.........not even to my 130,000 mile 2003 Z06
Pulling the intake should run you 1/2 hour, you'll need to remove 1 10mm bolt next to oil pressure sensor to put the socket on correctly for removal and install otherwise you risk braking the top off the new switch, ask how I know!
Do not try to short cut these things they always back fire on you and end up costing a great deal more.
and a set of (two) 11" long needle nose pliers. (Harbor Freight)
Very fast and easy/cheap job and a permanent inspection port.
oil pressure gage pinned
can anybody tell me if the gage gets pinned when an oil change is needed? my "oil life" is at 7% and my oil gage is now pinned, is this a coinsadance or does the oil sending unit need replacement?
if need replacement is it a big job to replace?
just did this about 3 months ago. I cut into my car. Why? well from a great number of posts it seems very likely that the POS sensor will fail again in the not to distant future, so I want a quick way to get back in there if I need to change it out again. I read a gazillion posts before deciding which way to go and went with the "cut" method. Believe me my car didn't bleed or cry when I cut it and it has completely recovered from the operation. You need the correct deep socket to do the job. Once I had the wiper arms off the car it took me 25 minutes to do the whole R&R. I patched the hole (make it big enough to get you hand thru it comfortably) in a way that will allow me to rerove the patch easily if and when the need arrises.
PS, I've pulled my intake maqnafold 3 times in the past and agree its not a big deal, I just like the idea of building a access hole for future use.
