**ECS Mantic Clutches install specials**
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
With winter coming now is the time to get your winter upgrades done and ready for spring!! so now and until the end of year we will be running install specials on some of our most popular items, starting with our Mantic clutch lineup we will be offering the following installed packages:
C5 installed packages include the following:
Mantic ER2 Single Street Series clutch kit
- Pressure Plate & Clutch Disc
- Pressure Plate Bolts
- Flywheel w/bolts
-GM Slave cylinder
-GM Pilot bearing
-ECS Remote bleeder kit
-Professional installation
Package price: $1,695.00
Mantic Twin 9000 Series clutch kit
-Mantic Twin clutch kit
-Flywheel w/ bolts
-All hardware
-GM slave cylinder
-GM Pilot bearing
Package price: $2,349.00
Mantic clutches are in stock and ready for install give us a call: 609-752-0321 and schedule your install today!!!
- Flywheel w/bolts
-GM Slave cylinder
-GM Pilot bearing
-Flywheel w/ bolts
-All hardware
-GM slave cylinder
-GM Pilot bearing
- Flywheel w/bolts
-GM Slave cylinder
-GM Pilot bearing
-Flywheel w/ bolts
-All hardware
-GM slave cylinder
-GM Pilot bearing
- Flywheel w/bolts
-GM Slave cylinder
-GM Pilot bearing
-Flywheel w/ bolts
-All hardware
-GM slave cylinder
-GM Pilot bearing
Anyone on the fence about which clutch or shop to use....give these guys a call, you'll be glad you did....
Thanks guys.....
