Optima Battery Questions
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
what's the difference between the red top and the yellow top, besides the obvious ;) :jester :cheers:
Re: Optima Battery Questions (Mean Green 2000)
I have a yellow top, and to my recolection the yellow top is a "deep cycle" battery capable of taking many complete discharges and still being able to be fully charged and operate normally, while the red top is similar to a regular liquid acid battery. I can't find the paperwork that was with the battery, but if I do I'll share it with you. :)
Re: Optima Battery Questions (Jim 47)
On the contrary---they are both totally sealed gel batteries---one being a deep cycle and the other higher amperage for cranking. :cheers:
CI III & IV Vote Ho
CI IV Bracket Champ
Re: Optima Battery Questions (tds69tx)
is there a better choice for our cars?
do most go with the yellow or the red?
:cheers:
:cheers:
Location: Various places in California. Not currently aflame.
I believe the deep cycle (yellow top) is better for people who use the battery for power when the car is off, such as folks demo-ing stereos at shows and such. If you just want the car to start reliably, I believe the red top is the way to go.
OK, found the borchure that came with the battery.
The Yellow top Deep Cycle Battery is recommended for :;Racing vehicles without a charging system, Diesel powered vehicles, Car audio applications, Electric vehicles, Heavy equipment with hydraulics, Any application where the battery is repeatedly deep discharged and recharged will require a "Deep Discharge" battery such as the yellow top.
The Red Top is recommended for; Automotive starting,, Recreational vehicles for under hood starting applications. Otherwise "normal" applications. It also says that "A deeper average discharge on a battery will result in fewer cycles over the battery's life."
Hope this helps. :D
Hope this helps. :D
Yes tds69tx, both the red top and the yellow top batteries are sealed SPIRALCELL technonoghy jell batteries. :yesnod: What I was trying to say was that the red top performed more like a regular liquid acid battery, while the yellow top was a deep cycle battery. :) Sorry for my misleading statement.
For normal driving the red top battery should be completely adequate.
CI III & IV Vote Ho
CI IV Bracket Champ
Re: Optima Battery Questions (DAWS C5)
thanks guys :cheers:
Re: Optima Battery Questions (SoonerC5)
I got my Optima Red Top battery from LAPD with overnight delivery!
Go with them....
Go with them....
Yep, the only thing is, someone needs to be home since FedEx won't leave it w/o a sig or you can go to the FedEx warehouse and pick it up later that day :yesnod: :lol:
Re: Optima Battery Questions (ghost.rider)
My red top was delivered on Friday, and no one was home to sign for it. So, at least in my case, a signature was not required.
Go with them....
Go with them....
:cheers:
:cheers:
Yes, AGMs haven't been around (in C5s) long enough for us to see just how long they will last, but if the AGMs in Miatas are any kind of example, we'll be likely to see a significant improvement in life over any of the competition's batteries.
BTW, deep-cylcle batteries generally have a shorter life than standard-type batteries if both are maintained properly.
Re: Optima Battery Questions (Dave68)
Went with LAPD here also for a Red Top. Can't go wrong with either. LAPD gives great price and service in my opinion.
Try to get the battery cover if you can. I had to contact Optima to get mine but it makes for a VERY CLEAN look.
I was told that for assured starting on a non-daily driver, the yellow top was the way to go. On a daily driver, the red top will suffice.
