Best replacement front wheel hubs
I need to replace the drivers side front wheel hub on my 99 Coupe, but I'm going to replace both. I've heard some people recommend the Timken Wheel Bearing/Hub assemblies ... are they good, or should I stick with the AC Delco part?
Mike
Mike
Either SKF or Timken branded front hubs will be fine for street duty. SKF also makes a race duty hub that is a bunch more expensive. I used the Timken and they have held up to five years of street and track abuse. Got them at the local Autozone parts store. I would not use the GM AC Delco stuff currently being sold, there were some reports of sourcing from China.
Make that 4 votes for SKF.
Unfortunately, since they're not a CF sponsor, I'm unable to hook you up with an SKF distributor, who has excellent pricing and service.....
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
got my Timkens for around $150 each. Just do an internet search (wink). BTW, you can interchange the front and rear, even though there are 2 part numbers.
Timken front wheel bearings/hubs
Thanks everybody. Locally the Timken are $154.00 and the SKF are $350.00 ... I'm replacing both front hubs, so I went with Timken.
